Author Topic: Rear washer leak  (Read 4086 times)
Rear washer leak
« on: April 03, 2017, 03:54:50 pm »
Tried the search but couldn't find anything definitive, but I went to use the rear wash / wipe today and instead of a nice fan of water being blasted onto the rear screen, instead I got some gurgling noises and a little dribble coming out of the washer jet.
Got to work and there was water dripping out the bottom of the tailgate cover inside.  Nice.
Before I go full gorilla on it yanking the cover off and probably breaking clips, are there any parts I need to arm myself with first?
Ta!
Offline doylebros
Re: Rear washer leak
« Reply #1 on: April 03, 2017, 07:44:21 pm »
« Reply #2 on: April 04, 2017, 06:17:55 pm »
Thanks mate. Ordered that and a bunch of other bits in the area  :smiley:
Offline flashp
  • -Receive: 65
« Reply #3 on: April 04, 2017, 10:20:05 pm »
I have a colleague who had this on an A3 and it was the washer jet which leaked back through the centre of the motor if I correctly recall what he told me at the time. He bought a new motor.
Gone but not forgotten :-)
« Reply #4 on: April 05, 2017, 09:47:23 am »
Thanks mate.  I ordered all of the replaceable bits.  Main glass seal, washer jet, the hose, the hose end and a couple of other bits.
I think I know why your friend replaced the motor.  The washer jet pushes into a plastic tube that goes through the motor and known to leak.  And guess what?  That plastic tube is only available as part of the entire assembly, soi I may end up doing the same if these bits don't fix it.
Offline mk1mad
« Reply #5 on: January 14, 2018, 04:37:10 pm »
Got the same problem, Pudding did you cure the problem and what part had failed ?
Edition 30
Golf Mk1 5vT
« Reply #6 on: January 15, 2018, 09:27:14 am »
Pretty sure it was just the plastic fitting that clips onto the wiper motor, but I ended up replacing that as well because the previous owner fitted a reversing camera, and chopped the motor up to make the camera fit  :stupid:
You can buy the fitting and a length of hose from VW to sort it.
Offline mk1mad
« Reply #7 on: January 15, 2018, 10:22:48 am »
Nice one thanks  :happy2:
Edition 30
Golf Mk1 5vT
« Reply #8 on: January 15, 2018, 11:08:10 am »
I would get a new washer jet insert as well.
Offline mk1mad
« Reply #9 on: January 15, 2018, 05:02:22 pm »
Thanks I'll add that to the list as well.
Edition 30
Golf Mk1 5vT
Offline mk1mad
« Reply #10 on: January 20, 2018, 05:25:24 pm »
Well it couldn't be straight forward it's leaking out of  the plastic at the bottom of the motor !
I am going to attempt a fix it  by using some araldite to seal the leak  as there is nothing wrong with the motor and a new motor is £130.
Edition 30
Golf Mk1 5vT
Offline mk1mad
« Reply #11 on: February 08, 2018, 09:27:40 am »
So the araldite cured one point of leaking, but it leaked else where.
So I needed a new motor looking through loads on eBay I found one with a vw parts sicker so it  must have been a replacement part.
Fitted up and works fine, point to note it is slightly different as the washer jet is in a fixed position and doesn't move with the wiper arm. Date on the motor 2015.
Edition 30
Golf Mk1 5vT
