Author Topic: Changing sidelight bulbs on factory xenons?  (Read 1107 times)
Offline petesimcock
« on: April 08, 2017, 04:58:01 pm »
Hi guys, I'm having tremendous trouble finding how to change the sidelight bulbs on cars with xenon lights. Someone mentioned going in through the wheel arch, anyone shed some light?
Offline v4rley
  • -Receive: 104
Re: Changing sidelight bulbs on factory xenons?
« Reply #1 on: April 08, 2017, 06:43:30 pm »
No need to go through arch, can be done from the engine bay. Remove plastic cap on rear of the lights, pliers are handy as bit tight inside the unit
Offline K9
  • VW LifeStyle
« Reply #2 on: April 08, 2017, 07:32:05 pm »
or if you have small fingers like me, then you can just pop the covers off and pull it out gently.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: April 08, 2017, 10:35:30 pm »
Don't know about gently as these buggers are sometimes jammed with the silly design of the side light cover which has a clip either side but can be done through the back cover as mentioned  :happy2:
Offline Dale
« Reply #4 on: April 11, 2017, 01:29:02 am »
There is a cerated bit on the bulb holder, get a small screwdriver behind the cerated bit and pry it against the side of the light. You might want to use a finger on the other side and pull at the same time. Pops out easy.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #5 on: April 11, 2017, 08:31:54 am »
I've a mini guide on the first page of my build thread
http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
It's tough getting in there and the bulbs are press fittings so a needle nose pliers will be needed to pull them out.
