Author Topic: To lower or not to lower that is my question  (Read 3642 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: April 08, 2017, 11:40:12 pm »
I'm in two minds whether I should lower the beast or not as I've got a complete H&R suspension set up inc top mounts as a kit so ready to bolt off and bolt on job?.
Re: To lower or not to lower that is my question
« Reply #1 on: April 09, 2017, 12:06:20 am »
You haven't already :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: April 09, 2017, 01:20:41 am »
No Andy been sat in the bedroom boxed up gathering dust  :signLOL:
Offline Newbieintown
« Reply #3 on: April 09, 2017, 03:22:51 am »
Same question really, I have a broken rear spring and wondering about lowering or staying stock. I use as daily driver so wouldn't want any to mental.
200bhp
Tornado Red
2006
Offline leebes
  • When's the next track day?
  • My Ride: 2007 Mk5 Gti (Reflex Silver)
« Reply #4 on: April 09, 2017, 05:23:31 am »
Lower it  :happy2:
Im on 30mm H&R springs and use the car for my daily commute (30 miles per day) and its not really any less comfortable than stock, but the handling and steering are much improved and sharper because of the spring.
Offline Ashjstarr
« Reply #5 on: April 09, 2017, 08:03:30 am »
Is there even an answer to this question that isnt 'of course you should'?
H&R sports were the best thing ive done to my car, daily driven 50miles a day mixture of motorway and B roads and it rides awesome and doesnt scrape anywhere
« Reply #6 on: April 09, 2017, 09:39:33 am »
Do you think it worth replacing the shocks also, as they are the same on there from day 1 and car is on 80k. Sorry to high jack this..... now what brand of spring? VWR or H&R? Only £25 difference.
200bhp
Tornado Red
2006
« Reply #7 on: April 09, 2017, 10:29:49 am »
You should in theory but ididnt change mine
« Reply #8 on: April 09, 2017, 10:31:03 am »
Am on the way to yours to lower it for you :signLOL:
Offline Octoparrot
  • -Receive: 102
« Reply #9 on: April 09, 2017, 10:41:30 am »
I've got a broken front spring so I decided to replace them all with the VWR set as it wasn't any more expensive than buying just the fronts from VW I then decided as its all going to be in bits I may as well change the top mounts and bearings, I then thought that I might as well replace the dampers while I'm at it with new OEM GTI ones along with all the new nuts and bolts you need to since the car is 10 years old and has 124k on the clock. It's turning out to be very expensive since I'm using all genuine parts even though the dealer gave me a 15% discount but at least I know it will all be ok for a long while afterwards. Something to think about perhaps?
« Reply #10 on: April 09, 2017, 10:42:18 am »
Where did you purchase from? Personally as you have it I would give it ago you can always revert back to standard.
200bhp
Tornado Red
2006
Offline colesey
  • -Receive: 89
« Reply #11 on: April 09, 2017, 11:05:36 am »
I had a set if vwr springs (and sports dampers) fitted last year and wouldn't hesitate to recommend them. Not only does the car drive (and look) much better, however they also retained oem level comfort.
« Reply #12 on: April 09, 2017, 11:14:56 am »
What dampers did you go for bud?
200bhp
Tornado Red
2006
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: April 09, 2017, 12:06:07 pm »
london E1  :signLOL:
Only reason I'm worried is because I'm already catching the speed bumps with my ED30 spoiler and these bumps aren't small you hear me?, check my thread for the one on my road and the cars standard ride height ATM so a little concerned it will be ripping the front off if I lower. Only real was to do this is to fit them and see what happens isn't it  :doh:
My tt was very low and with the votex over spoiler and LCR splitter is was stupidly low but again will only know once fitted.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: April 09, 2017, 12:08:13 pm »
Lower it  :happy2:
as post above this I'm just scared of damaging my car as I know the perks of having them fitted. Just fitted my H&R roll bars and the steering is nice and tight now with less body roll too so handles very well  :happy2:
