Author Topic: Neg Camber  (Read 8088 times)
Offline firesafetydave
Re: Neg Camber
« Reply #15 on: April 12, 2017, 11:54:26 am »
Car is only a weekend toy, track car.
What are the other settings you would recommend?
i presume max caster, no toe on front as this causes tyre wear, 2.5-3 neg camber.
What about the rear/ i have adjustable arms.
Thanks again for input
Re: Neg Camber
« Reply #16 on: April 14, 2017, 05:48:54 am »
Just picked up a new set of supaloy lower arms and antilift
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Neg Camber
« Reply #17 on: April 14, 2017, 07:34:28 am »
Tiny bit of toe in 0.5 mins and -2 on the rear, same 0.05 mins toe in
Re: Neg Camber
« Reply #18 on: April 14, 2017, 10:19:42 pm »
Thanks Freddy,
What geo do you run front and rear as I'm new to vag set ups having had rwd for years? Ta
Offline M4T VW
Re: Neg Camber
« Reply #19 on: April 24, 2017, 08:51:59 am »
Just had mine setup with super pro ball joints and also KW clubsports so adjustable top mounts. The max we could get was -3 on the front which I was surprised at as I thought the both of them combined would have given more. I have maxed out the ball joints and topmounts for -3 but may take that back a notch depending on tyre wear.
For the rear I went with -1.5, I prefer a planted rear so not too loose. Not tried it on track yet so hopefully it's good. It's about what my MK2 was setup like
Re: Neg Camber
« Reply #20 on: April 24, 2017, 10:40:36 pm »
Keep me informed, sounds like a nice setup
