Author Topic: Anyone tried the VWR "Cup Edition" alloy wishbone set?  (Read 10183 times)
Offline Christiank
  • -Receive: 39
Re: Anyone tried the VWR "Cup Edition" alloy wishbone set?
« Reply #15 on: April 20, 2017, 05:50:54 pm »
Think it's the same partnumber for both sides.
So you wouldn't have any thoughts on buying a pair that has 150.000km?  :innocent:
« Reply #16 on: April 21, 2017, 09:11:18 am »
So long as they are straight, 150,000km is no problem.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #17 on: April 21, 2017, 10:11:32 pm »
Yeah they can be a bugger to get off, so most sellers leave them on!
No worries!
They arrived today, needs a good clean lol
Weighed them, 3kg each, that's including the console....sound about right?
Offline Christiank
  • -Receive: 39
« Reply #18 on: April 21, 2017, 10:18:53 pm »
Sounds good. I ordered some today myself. Should arrive mid next week. Also purchased some sodablower gear to clean em up.. Guess I'll give all parts in beneath the car a run over to clean the bits up. :)
« Reply #19 on: April 24, 2017, 09:29:01 am »
No worries!
I didn't weigh mine mate, but Shodouchi reckoned the steel ones are 4kg and the Passat ones are 2kg, less the consoles I assume.   I can quite believe that because when I held both in my hand, the Passat one was considerably lighter!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #20 on: April 24, 2017, 12:51:21 pm »
No worries!
I didn't weigh mine mate, but Shoduchi reckoned the steel ones are 4kg and the Passat ones are 2kg, less the consoles I assume.   I can quite believe that because when I held both in my hand, the Passat one was considerably lighter!
That's it. Without consoles since I just needed the wishbones. I kept my PU bushes, front from Powerflex and rear from SuperPro with anti-lift kit. I also bought new Passat ball joints. :smiley:
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #21 on: April 24, 2017, 12:56:14 pm »
@Pudding @Shoduchi Will the gti ball joints be ok on the Passat wishbones?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #22 on: April 24, 2017, 12:58:53 pm »
Yes, but the Passat ball joints will correct a bit the roll centre. You just need to use new nuts for your ball joints. They're one use only, ideally.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #23 on: April 24, 2017, 01:28:28 pm »
Ta getting all the bits in before Saturday, just need to order the ball joints then. Hopefully I don't regret going for the black series ALK and front bushings, 95 shore!
Purple is 80...
Will have to wait and see if I knock my fillings loose
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #24 on: April 24, 2017, 01:34:15 pm »
Purple is 80...
If you don't track the car I don't think the Black series is advised... I have road series SuperPro ALK and it has done 4 track days so far. No issues. It has some compliance to lessen a bit the road NVM.
Offline Christiank
  • -Receive: 39
« Reply #25 on: April 25, 2017, 08:20:21 am »
So I'm getting my alloy wishbones from the B6 Passat along with some Audi TT bushes from darkside developments.
@Shoduchi should I just ring up VW and order some now ball joints from a passat b6 or which did you go with? :)
Also is there anything else I need to order before I can get them installed?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #26 on: April 25, 2017, 10:30:52 am »
Not sure about the TT bushes. I prefer them from SuperPro that I also have in my GT Sport (the ones with anti-lift).
You can see what I did when I made that upgrade with part numbers included here: http://www.mk5golfgti.co.uk/forum/index.php/topic,95592.msg1079220.html#msg1079220
 :wink:
Offline Christiank
  • -Receive: 39
« Reply #27 on: April 25, 2017, 11:14:50 am »
Went with the TT/S3 ones since my xar actually will never see a track day. So just trying to improve the ride for some highway trips :)
-Left ball joint: 3C0407365B
-Right ball joint: 3C0407366B
-Nuts: 6x N10332002
These partnumbers will also fit my 3C0407153B  wishbones?  :innocent:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #28 on: April 25, 2017, 11:52:50 am »
-Nuts: 6x N10332002
I don't and won't ever track my diesel GT Sport but I loved the handling improvement that the SuperPro rear bushes with anti-lift gave, without compromising the driving comfort.
The parts listed are used in all Passats B6, so they're all compatible. Your wishbones are just a different revision from mine.
Offline acko2204
  • -Given: 19
« Reply #29 on: November 26, 2017, 05:49:11 pm »
Anybody know the difference between these two parts of any..Passat B6 front control arm:-3C0407153B and also found control arm:-3C0407151G which says Passat/Sharan and other VAG cars
Both look identical to me 😕
