Author Topic: VW Unable to remove Revo...  (Read 3948 times)
Offline edition_30
« on: January 31, 2010, 08:22:33 pm »
Visited a main dealer on sat as i wanted the revo removed.. anyway got the car hooked up to the computer only to be told about an hour later than they could not overwrite the revo software..
Anybody ever have this as im eager to go back to standard map..
Offline KRL
  • -Receive: 29
Re: VW Unable to remove Revo...
« Reply #1 on: January 31, 2010, 08:27:57 pm »
Why do you want it removed?
You can switch back to stock settings using an SPS or SPS+.  Failing that just go back to your tuner and they can either put the map back to stock setting or completely remove the sw if you want.
When a main dealer flashes your car (i.e. VW dealer) they compeltely re-write the ECU so I am surprised they could not flash yours.
« Reply #2 on: January 31, 2010, 08:29:40 pm »
im pretty surprised they couldnt do it.
im almost certain they would have come to the first hurdle and given up with a "computer says no scenario"
Offline icenutter
« Reply #3 on: January 31, 2010, 08:30:14 pm »
Alternatively why not take it to the Revo dealer that installed it for you?
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
Offline edition_30
« Reply #4 on: January 31, 2010, 08:31:57 pm »
they said that it was something to do with the revision of original software i had. I have the full print out where it goes thru checking the system.. he said just by looking at it there was no way to tell wether it was mapped or not.. never knew my tuner could replace the map.. does that mean then it will go back to original vw map..
« Last Edit: January 31, 2010, 08:34:40 pm by edition_30 »
Offline Pauli
  • ED30 Candy White
« Reply #5 on: January 31, 2010, 08:54:29 pm »
Was told an ecu update at main dealer should standardise your car. Has been known to happen accidentaly
MK6 3dr CW GTi with Dynaudio, 18" Monza Shadows, Winter Pack, Luxury Pack, Rear View Camera, Underseat Drawers. ED30 Gone But NEVER Forgotten.
« Reply #6 on: January 31, 2010, 09:01:07 pm »
Skoda had no problems updating my ECU exactly 3 hours after I had Revo stage 2 loaded.  :sad1:
Offline rubber toe
« Reply #7 on: January 31, 2010, 09:14:35 pm »
i think if your car has the current sofware version installed in the car ( mapped or not ) vw cannot overwrite the file .
be better off taking it back to the revo dealer  :smiley:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: January 31, 2010, 09:27:31 pm »
That's correct, so far as I know the VAS system will check the car Chassis number and ECU revision.  If the criteria for update aren't met the computer says no.
Stu...
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #9 on: January 31, 2010, 10:11:48 pm »
So how comes you are taking it off?
« Reply #10 on: January 31, 2010, 10:12:26 pm »
I believe even if all criteria are met it is possible to force an update but that involves a connection to the factory and lots of questions.  :wink:
Offline revo carl
« Reply #11 on: February 01, 2010, 09:24:05 am »
the reason they couldn't do it is because your car isn't due an update..... therefore their tools will not flash your car.
VAS will only flash an ECU which needs an update.
Offline Garth
    • My Build thread
« Reply #12 on: February 01, 2010, 10:05:59 am »
I had Revo on my old S3 and didn't like it, so a friendly Revo dealer re-flashed me back to stock for free  :smiley:
There are lots of reasond he might want it removed. For example, when I had it, I wanted a remap by another company and they couldn't/wouldn't touch it with the Revo software on it. Switching it with the SPS only reverts to stock power, NOT stock software. There's a diference  :wink:
Offline edition_30
« Reply #13 on: February 01, 2010, 10:38:55 am »
so if i contact my revo dealer then will they be able to re flash back to original vw image?
Offline KRL
  • -Receive: 29
« Reply #14 on: February 01, 2010, 10:44:10 am »
You misinterpreted my post, at no point did I say it reverts back to the stock VW map.  Read again  :wink:
