Author Topic: 2006 golf 2.0 Gttdi problem  (Read 765 times)
martink
« on: April 18, 2017, 12:46:10 am »
Hey all
New on here and looking for a bit of help please
I recently bought a 2006 golf 2 litre gttdi
Fully serviced it on Saturday morning
Car has done near 150 mile since serviced
Now out of the blue it is cutting out with no warning
This morning I started it in my driveway. It started 100%. Left it idling for about 20mins on the driveway when it cut out. No warning at all. Tried starting it again and it cuts out after 10seconds. Before I get the tools out I was wondering has anyone came across this before.
All help appreciated folks
Offline B1NCC 1.8T
Re: 2006 golf 2.0 Gttdi problem
« Reply #1 on: April 18, 2017, 10:29:00 pm »
I've had this a few times when the G28 crank shaft sensor fails. Trickey wee thing to replace on the 2.0tdi
But I would advise getting a diagnostic scan done. See what's coming up.
20vt mk2 & GTI Edition30 no 0540
« Reply #2 on: April 18, 2017, 10:36:35 pm »
Check the pump is working in the fuel tank
Offline Stupots
  • -Given: 18
« Reply #3 on: April 19, 2017, 06:43:11 am »
Could be this. First thing to check is that the connector is on it 100%, this is found between the Oil Filter/Cooler housing and the gearbox. It's awkward to get to, but with a torch and a looong screwdriver or suitable prodder, you can push on the connector to ensure it's fully home. If you have to change it, it's a bit of a job (front off/oil cooler housing off at the very least I would say)
If not and to save all the guess work, as B1NCC says, find someone near you with a VCDS/VAG-COM. Good luck.
Stu
