October 05, 2024, 10:45:55 pm
All Things Mk5
Technical Workshop
Cam cover sealant
Topic: Cam cover sealant (Read 2055 times)
Tommihayes
Taking part
-Given: 1
-Receive: 1
Cam cover sealant
April 21, 2017, 08:38:17 am »
Hello,
I've seen that I need to use D154 103 A1 sealant for the cam cover ladder, but is there a loctite or hylomar alternative?
I've had a really good look and one person suggested hylomar blue but I wanted to be sure.
Tom
rich83
Just look at my post count
-Given: 165
-Receive: 802
My Ride:
Re: Cam cover sealant
Reply #1 on:
April 21, 2017, 08:59:01 am »
I would only use the OEM green stuff that you mention.
https://www.justgiving.com/thenational3peaks
pudding
Global Moderator
-Given: 2
-Receive: 685
Reply #2 on:
April 21, 2017, 10:09:54 am »
Wurth Green flange sealant WU0893573050 is a good alternative and roughly half the price.
Don't even think about using £5 sealants from Halfords. Use the proper stuff or don't do the job until you've saved up for it.
Ask on the TFSI tuning group too. There must be loads of bottles of this stuff kicking about from cam jobs that's going spare.
Tommihayes
Taking part
-Given: 1
-Receive: 1
Reply #3 on:
April 21, 2017, 10:49:15 am »
I wanted to use an equivalent sealant that was as good or the same as standard so thanks for the advice. After my third look I've found the TFSI group and just sent a join request! Thanks!
pudding
Global Moderator
-Given: 2
-Receive: 685
Reply #4 on:
April 21, 2017, 01:39:43 pm »
That's the thing, most things aren't as good as OE, but some detective work can often lead you to the path of the OE manufacturer
I'm sure someone on there will sell you the remains of their bottle for a tenner! That's assuming you don't need an entire bottle to do a cam cradle job.
All Things Mk5
Technical Workshop
Cam cover sealant
