Has anyone fitted them to a GTI?
I noticed whilst fitting Passat wishbones to mine that my WALK bushes are worn out, which is a well known 'creep and set' issue with polyurethane.
Ages ago I bought some S3 bushes and I went to fit them, but discovered the housings are 10mm offset, which would push the wishbone down and therefore increase positive caster, which will then need an alignment?
Is that the only difference? Everything else looked the same.
