Author Topic: GTI Engine Temperature Gauge Fluctuation  (Read 2219 times)
Offline ChrisPeers
« on: April 23, 2017, 10:30:11 pm »
I've just taken ownership of a 90,000 mile GTI. It's got FSH and receipts for all work and is in good condition and completely standard so I believe I got a good one.
I drove it back from Yorkshire today and on the ride home I noticed that the engine temperature gauge fluctuated continually between 70 and 90 degrees which left me slightly concerned.
When I slowed down to say 50 or 60mph the gauge dropped to 70 degrees but when I kept the engine at 80mph or above it went back up and sat just under 90 degrees as though it was normal.
At idle the gauge sits at a fraction under 90 degrees. Which seems normal but I've never owned a car where that gauge moved unless there was a problem.
Should I be worried or is this common?
Any help appreciated.
Offline peter_booker2003
Re: GTI Engine Temperature Gauge Fluctuation
« Reply #1 on: April 23, 2017, 10:50:17 pm »
Sounds like the thermostat to me. Common problem as they get stuck open. Worth getting sorted as you will find mpg will be down as a result. Looking at £200 ish fitted at a local indy.
Past: MK5 Golf GTI, Black Magic Pearl, Xenons, SatNav, MFSW, Highline
Past: Edition 30 #1411, Tornado Red, Xenons, Revo Intake, H+R Springs, Highline, DSG,
Current: Mk5 Golf GTI, Steel Grey, 3dr, Manual
Offline Deegti
« Reply #2 on: April 24, 2017, 07:47:56 am »
It's the thermostat alright,I just replaced mine last weekend as I was having the same symptoms as you,30 quid from eBay for a genuine part and 3 hours labour with plenty of swearing and bloody hands lol.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: April 24, 2017, 08:47:02 am »
Is it manual or DSG?
They both have a main thermostat and an inline thermostat.
DSG has one additional inline thermostat.
Main:
This is a pig of a job and unless you're very capable you will need a garage to do it.
Issue is that the engine never reaches 90 unless in traffic, drops to 60 or so while cruising.
Inline:
Not too bad to change.
Issue is that it takes the engine often up to an hour to get to 90. It should take 4 mins or 2 miles give or take.
My build thread shows my inline being replaced - http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
Offline ChrisPeers
« Reply #4 on: April 24, 2017, 11:13:33 am »
Thanks. I've got the DSG version. I'm definitely not capable of doing the work myself. Garage it is.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #5 on: April 24, 2017, 11:36:32 am »
Does anyone know if a bad thermostat would cause a loss in performance?
Only asking as there was a mk5 on a dyno once and it was 20bhp down on power as the car wasn't up to temp yet. When it was up to temp it pulled bang on figures.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #6 on: April 24, 2017, 11:42:44 am »
The ECU limits power on low temperature to protect the engine.
As to what level of restriction I cannot say.
20bhp would have been a good guess.
