Author Topic: Newbie seeking advice - stereo with bluetooth and DAB wanted  (Read 4180 times)
Offline Holmsie
« on: April 27, 2017, 10:24:33 am »
Hi all,
Just bought a Mk5 GTI and loving it so far... apart from the standard stereo.
I'm after an OEM-looking stereo that has bluetooth audio and DAB radio, not bothered about sat-nav.
What are my options and how much am I looking at for installation? Would it need an adapter to stop battery drain and a new aerial etc.?
Cheers.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Newbie seeking advice - stereo with bluetooth and DAB wanted
« Reply #1 on: April 28, 2017, 07:59:31 am »
@olsen-72
Alex (tagged above) has radios for sale.
Can supply and fit gateway too
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #2 on: April 28, 2017, 08:04:22 am »
Hi
I sell and fit OEM headunits.
There is only one radio with all of that functions. RNS315 has BT, DAB and satnav.
If you looking just for DAB radio than RCD510 but than you will need separate BT module and wiring.
So really depends what you want.
Drain depends of year of the car. Later 57 plate and above dont have that problem. Anything below you will need new gateway.
I supply and fit all of the parts. Please inbox me if interested.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Holmsie
« Reply #3 on: April 28, 2017, 08:13:35 am »
Cheers lads.
Olsen-72, for some reason I can't send you a PM? If you can send me one that'd be great ta!
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #4 on: April 28, 2017, 08:27:39 am »
Cheers lads.
'Can't read PM's yet'
You need to make 10 posts.  just another posts 6 to go :)
Offline Holmsie
« Reply #5 on: April 28, 2017, 08:32:34 am »
It's letting me send PMs to other members though, hmm...?
What's the satnav like on the RNS315? I usually use Waze or Google maps on iPhone.
willni
« Reply #6 on: April 29, 2017, 09:22:48 am »
Depends on what maps are on it, 7th version and on maps are very good. I have one with the very first maps on it and they're crap
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #7 on: April 30, 2017, 10:02:32 pm »
Ive just fitted an rns315 dab with v7 maps & a polo shark fin aerial & im very impressed plus the dab - satnav - phone kit & fm / am are all running through the roof aerial so great coverage.
The dab is a big plus for me as it means i ant got to listen to all this modern pop crap anymore, bring on the 80's tunes  :jumpmove:
Offline Holmsie
« Reply #8 on: May 01, 2017, 08:18:26 pm »
That is what I'm after! Where did you get the unit from and which shark fin aerial is it? Searching on ebay it brings up hundreds...
Offline mrxbox360
« Reply #9 on: May 01, 2017, 11:16:55 pm »
pm ed you
Drizzt29
« Reply #10 on: July 16, 2017, 09:08:57 am »
Hello chaps,
Just reading the above thread and I'm in exactly the same position. I'm looking to replace the current,  standard,  head unit and the rns315 sounds what I'm looking for. I've got a mk5 (58 plate) so this battery drain issue wouldn't be present right?
Appreciate any feedback! First post newb here.
willni
« Reply #11 on: July 16, 2017, 11:50:03 am »
Hello chaps,
You'll get battery drain with the rns 315 all 2nd gen versions give battery drain, so will need a canbus upgrade alternatively you can get an rns510 and have it coded not to drain the battery
Offline xs2man
  • -Given: 18
« Reply #12 on: July 16, 2017, 02:56:45 pm »
Hello chaps,
Thats not 100% accurate.  Some late 07's and later had the correct revision canbus to avoid battery drain, so he could just have a look at his canbus gateway first to find out.  Obviously the easiest way is to scan with VCDS and find out, alternatively he could just physically find it, remove it, and check.
4ndy
« Reply #13 on: July 16, 2017, 03:02:20 pm »
Hello chaps,
March 2017 "K" version gateway NO drain
Offline xs2man
  • -Given: 18
« Reply #14 on: July 16, 2017, 03:05:45 pm »
Hello chaps,
Ha ha.  I had a March 07 gateway, but decided to swap it out in advance just in case.  The car is used almost daily, so didn't want to take the risk.  I guess it might be worth "something" after all.
