Author Topic: Scirocco Clocks  (Read 4393 times)
Offline Hendry
Scirocco Clocks
« on: April 28, 2017, 01:26:02 am »
Spotted these on eBay from a 2015 Scirocco TDI, just wondering if these would works in a 2009 Jetta 2.0 CR TDI Sport which current has no MFSW, and midline clocks with computer functions operated via wiper stalk (I am planning to upgrade to MFSW when I can find one cheap enough)
http://m.ebay.co.uk/itm/2015-VOLKSWAGEN-SCIROCCO-2-0-TDI-SPEEDOMETER-SPEEDO-CLOCKS-1k8920875d-/361964218854?hash=item5446bfa9e6%3Ag%3ACuwAAOSw-3FZAcA4&_trkparms=pageci%253Abe092636-2ba8-11e7-bb57-74dbd1a043db%257Cparentrq%253Ab1efe29415b0a99bea4913daffffcfb6%257Ciid%253A1
Offline Christiank
  • -Receive: 39
Re: Scirocco Clocks
« Reply #1 on: April 28, 2017, 09:10:24 am »
Hi.
The actual shape does fit the mk5.
If you're planning to reaplce you steering wheel to er mk6 or newer you also have to replace your steering control module. Should be replaced to 1K0 953 549 CH.  Also if you have cruise control you'll be needing to swap out the old stick to a new one ending in "G".
You should also change you wiper stalk to 1K0953519H - That way you'll clear the error with vcds saying that you steering wheel electronic isn't coded right.
Also you'll be needing this cable : http://www.ebay.com/itm/36-32-Pins-Plug-Cluster-Adapter-For-VW-Passat-B6-Scirocco-Touran-Skoda-Octavia-/162295818840?hash=item25c995aa58:g:FjgAAOSwHMJYOHtW&vxp=mtr
Pretty sure you can find it in the UK ebay also from a nation seller. The link was just to give you an idea of what the cable looks like.
When all this is replaced and installed there's the whole coding of the Scirocco cluster and the immobilizers
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
Re: Scirocco Clocks
« Reply #2 on: May 02, 2017, 12:14:47 am »
Hi you might wanna check that cluster can be done as i was told 2013 onwards cant be done, im looking to swap my clocks from highline to maxidot & ive a ch controller fitted with flat bottomed mk6 wheel.
Offline Christiank
  • -Receive: 39
Re: Scirocco Clocks
« Reply #3 on: May 02, 2017, 09:12:01 pm »
Who told you that?
I've got a 3D cluster from a Tiguan in my mk5 .. Working with immo and all
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Scirocco Clocks
« Reply #4 on: May 03, 2017, 08:14:50 am »
@olsen-72
Pretty sure Alex can....
He's fitted 3d colour cluster in my car, with needle sweep & miles to empty.
Also mk6 & later mk7 MFSW to my car and everything works.
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline spicypixel
Re: Scirocco Clocks
« Reply #5 on: May 03, 2017, 08:18:35 pm »
Got a rough price on what that cost? Clocks and Mk7 wheel sound tempting.
Mk5 GT TDI 170 - MY2007
Offline shoaybmakda
  • -Receive: 54
Re: Scirocco Clocks
« Reply #6 on: May 03, 2017, 10:04:11 pm »
Apart from the usual suspects who else can retrofit these clocks?
