November 17, 2024, 02:45:25 am
All Things Mk5
Mk5 General Area
Turbo radial shaft play?
Topic: Turbo radial shaft play? (Read 1000 times)
Sulley91
Taking part
-Given: 2
-Receive: 0
May 01, 2017, 07:25:52 pm »
Brought a new genuine k04 turbo from vw, I've noticed its got a bit of play side to side but not in and out is that normal? Doesnt hit the walls or anything , it has about 1mm or so play
Last Edit: May 01, 2017, 09:24:38 pm by Sulley91
fab5freddy
Just look at my post count
-Given: 238
-Receive: 239
Re: Turbo radial play?
Reply #1 on:
May 01, 2017, 09:25:03 pm »
Yes, I think it's normal, the little bit of "slack" you speak of should be taken up by the oil pressure once up and running, that's to my understanding.
Someone with more mechanical engineering knowledge might be able to elaborate..
pudding
Global Moderator
-Given: 2
-Receive: 690
Re: Turbo radial shaft play?
Reply #2 on:
May 02, 2017, 09:29:19 am »
It's good to know they're like that from new because my 110K old KO4 also has approx. 1mm of play. I thought it was f'cked so bought a TTE420 (any excuse eh?)
As above, you'd expect most turbos do have a little play in the shaft/bearings to allow space for oil. I remember my old ball bearing Garrett GTxxxxR turbos had play when brand new also, so it must be normal.
If you're not happy with your new turbo, I'm more than happy to swap it for my old one
All Things Mk5
Mk5 General Area
