Author Topic: Problem with window modules gen 3  (Read 7070 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: May 04, 2017, 08:06:43 pm »
Today I fitted my gen 3 window modules off a seat Leon on to my gti but they don't seem to work  :sad1: anyone have any ideas thanks
PN 1K0959793N
PN 1K0959732N
Offline SI-R32
  • -Receive: 125
Re: Problem with window modules gen 3
« Reply #1 on: May 04, 2017, 08:12:33 pm »
What's the problem? How old is gti
Offline v4rley
  • -Receive: 104
« Reply #2 on: May 04, 2017, 08:15:04 pm »
05 and 5 dr I believe  :scared:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 04, 2017, 08:20:11 pm »
Yes thanks Varley, @SI-R32 it's an 05 November gti mk5 more door
The ones I have are gen 2 I believe and last letter is H
« Last Edit: May 04, 2017, 08:22:34 pm by r5gtt »
Offline SI-R32
  • -Receive: 125
« Reply #4 on: May 04, 2017, 08:21:59 pm »
You'll have gen 2 wiring, if your fitting gen 3 there will be lots of pin changes needed, did you have a read of this on my gti. Com
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 04, 2017, 08:24:54 pm »
cheers mate I read something you posted on here a while back but didn't realise I'd have this issue. Is there anyway around this as Alex said it will work fine hence I bought them and tried fitting in today but only left windon button unlocks doors  :doh:
Offline SI-R32
  • -Receive: 125
« Reply #6 on: May 04, 2017, 08:28:22 pm »
Early golf's had slightly different wiring to later golf's on the window modules, if it's a gen 3 module it will only work in later golf's unless you do a few pin changes in possibly 2 plugs, as yours is an 05 car you'll defo have gen 2 modules fitted, it's not to bad to repin the plugs
Offline SI-R32
  • -Receive: 125
« Reply #7 on: May 04, 2017, 08:29:19 pm »
Why you changing, folding mirrors?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: May 04, 2017, 08:52:11 pm »
Im not changing them but wanted to add the remote option to it and if you had a diagram to maybe Assist me that would be awesome?.
Offline SI-R32
  • -Receive: 125
« Reply #9 on: May 04, 2017, 08:59:32 pm »
If you can wait I'll sort something out for you, right now I'm laid up with back problems, so can't use the laptop. But I can send wiring diagrams of the different connections
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: May 04, 2017, 09:21:42 pm »
yeah I'm in no rush thanks and hope you recover soon mate as I know what it's like to have an issue with the body  :sad1:
Offline Christiank
  • -Receive: 39
« Reply #11 on: May 05, 2017, 02:12:52 pm »
Hey mate.
Do you have both part numbers for the new gen 3 modules and motor?
There so many different numbers with these freaking modules :fighting:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: May 05, 2017, 02:18:26 pm »
Hey mate.
i was going to message you last night but it got late lol the ones I've got only work with 2007 and above  :doh: there aren't different number it's the letter at the end you need to look for
« Last Edit: May 05, 2017, 02:20:29 pm by r5gtt »
Offline Christiank
  • -Receive: 39
« Reply #13 on: May 05, 2017, 02:30:59 pm »
There is 2 numbers 702 "x" and 792 "x"
So the 792N will always allow mirror fold no matter what part number the motor has?
Like this one
http://www.ebay.de/itm/1K0959701AC-1K0959793N-VW-Golf-5-Jetta-Passat-3C-Fensterheber-Tursteuergerat-VL-/222496137508?hash=item33cdcda124:g:FgEAAOSwR29ZCDdy
Will this be a max module? :smiley:
« Last Edit: May 05, 2017, 02:37:50 pm by Christiank »
Offline em2evol
  • Let's Motorvate!
« Reply #14 on: May 05, 2017, 10:23:33 pm »
Sorry to jump on your post but I had to change my drivers door window motor as the old one cooked itself and when the new one was fitted and all the buttons worked the wrong thing VW didn't want to know and they're trying to blame it on my car! So what we are saying is the current gen modules definitely won't work in an early mk5? What's the fix for this?
