Author Topic: RNS510 - Differences in versions b & c and firmware 1100 & 2600  (Read 12645 times)
Offline devilt
Re: RNS510 - Differences in versions b & c and firmware 1100 & 2600
« Reply #15 on: February 03, 2010, 09:34:59 pm »
Any luck Lyons?
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #16 on: February 03, 2010, 10:28:11 pm »
PM me...I can provide details of how to get the DVD playing whilst on the move.
Thanks mojo, will do when I get 10 posts. You can email me if you like, email addy is in profile.
Sorry for not getting back sooner devilt.  I think Lyon has kindly dug out the forum post...
Let me know if you need any further info.
  • MUBster DUBster
« Reply #17 on: February 03, 2010, 10:29:50 pm »
I can confirm the DVD playback "hack" works on firmware 1200 and 2600.  I have a rev. C unit.
Offline devilt
« Reply #18 on: February 03, 2010, 10:31:47 pm »
Nice one.
I am getting a version B as I have a 56 GTi, how old is your car? If old as mine do you suffer from battery drainage?
Offline Lyons
  • -Given: 18
« Reply #19 on: February 03, 2010, 10:36:24 pm »
APologies, forgot all about it! I have a dvd sitting beside my keys so ill try it in the morning.
My car is 07 and i have a version B with no battery drain.
FW1100 doesnt suffer from battery drain.
  • MUBster DUBster
« Reply #20 on: February 03, 2010, 10:52:52 pm »
Nice one.
I think the battery drainage issue is related to the CANBUS revision...anything above later than rev. K is fine... may be someone on the forum can elaborate further...
« Last Edit: February 04, 2010, 12:57:04 pm by xxx_mojo_xxx »
Offline Lyons
  • -Given: 18
« Reply #21 on: February 04, 2010, 07:50:16 am »
No joy im afraid.   :sad1:
Offline devilt
« Reply #22 on: February 04, 2010, 09:40:36 pm »
No worries, thanks for checking.
Offline devilt
« Reply #23 on: February 04, 2010, 09:42:07 pm »
Thanks. Do you know how I can check what Canbus version I have.
Also is it quite easy to upgrade from 1200 to 2600?
  • MUBster DUBster
« Reply #24 on: February 04, 2010, 09:47:23 pm »
VCDS (VAG-COM) tells which revision of the canbus is installed.
I have the image for 2600 - which I can some how get over to you.
Offline devilt
« Reply #25 on: February 04, 2010, 10:04:05 pm »
That would be good, I will give you a shout when I need it. Still one thing confusing the hell out of me, the difference between a B version and a C version.
I read the C version has DAB, so does this mean it is the whole RNS510 unit that is different?
  • MUBster DUBster
« Reply #26 on: February 04, 2010, 10:26:24 pm »
I have rev C - and it certainly doesn't have DAB.
Offline ollie288
« Reply #27 on: February 04, 2010, 10:27:58 pm »
Have you added the DAB aerial?
In a thread it says that the C has DAB.  :confused:
  • MUBster DUBster
« Reply #28 on: February 04, 2010, 10:30:07 pm »
No where in the menu system is there a DAB option...not even "greyed" out (disabled).
Where would the DAB aerial normally be situated?
Offline devilt
« Reply #29 on: February 04, 2010, 10:31:04 pm »
Mmm, you may have an earlier version of C then, look at the first post on page 10 of this thread:
http://www.mk5golfgti.co.uk/forum/index.php?topic=9605.135
