Author Topic: I need help installing a boost gauge.  (Read 3243 times)
Offline Apearcey
« on: May 08, 2017, 09:00:56 pm »
As the title says, I want to install a boost gauge... but I have no idea where to begin!
I'd like to get an electronic one cause I'm a bit of a geek. But where do I begin?! This is my first turbo car.
Any help at all is greatly appreciated!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: I need help installing a boost gauge.
« Reply #1 on: May 09, 2017, 01:14:32 am »
Wire up the gauge to the fuse box right hand side of the dash behind the cover and I'd get a fuse tap.
Depending on what colours
Red -- 12V accessory Power
Black -- Ground negative
White -- Engine accessory power
Orange -- Head light switch (12V switch power)
Green -- Boost sensor (connect to green wire from sensor)
Vacuum - you will need a boost tap for this coming off the Pcv valve
Offline Paradox1
  • -Given: 41
« Reply #2 on: May 09, 2017, 11:31:45 am »
just wire it to the headlight switch. take 10 mins to do the wiring. run the vacuum hose behind the battery
Offline mkmg76
« Reply #3 on: May 09, 2017, 04:19:02 pm »
I used one of these, they're multi coloured and match the dash well.
http://www.ebay.co.uk/itm/Digital-52mm-Turbo-Boost-gauge-35-psi-Red-Blue-Mitsubishi-Evo-1-2-3-4-5-6-7-8-9-/172381258675?hash=item2822b943b3:g:AA8AAOSwrklVI5ez
All of the vacuum hoses are under the bonnet so all you need to run into the cabin are the wires which provide the info to the gauge itself. Much easier!  :happy2:
Picture here of it installed (about half way down the page).
http://www.mk5golfgti.co.uk/forum/index.php/topic,30806.10020.html
