Author Topic: Numberplate lights led confusion.  (Read 2449 times)
Offline Chrisl85
« on: May 09, 2017, 11:08:50 am »
Having a bit of a headache with this. Normal bulbs are working fine. Plug one led in, still fine. Go for 2 and nothing. I've rotated them incase their polarised but nothing. Whats going on? Thanks
Sent from my SM-N915F using Tapatalk
Offline chimp400
  • -Given: 46
Re: Numberplate lights led confusion.
« Reply #1 on: May 09, 2017, 11:40:07 am »
Its normally incompatible bulbs that do this, not suitable for the bulb recognition or can systems.
Offline Chrisl85
« Reply #2 on: May 09, 2017, 12:23:17 pm »
Gone back to shop. Gentleman fired some mumbo jumbo at me. The car won't accept the type of bulbs i used for some confusing reason. Tried led sidelights for the car whelse I was there and the car dont like them either! How do people upgrade all their lights to white help!!!
Offline Leco_GTI
« Reply #3 on: May 09, 2017, 12:32:34 pm »
I believe you will need lights that are CANBUS error free.
Offline andy7ven
  • -Receive: 30
« Reply #4 on: May 09, 2017, 12:32:59 pm »
These are what I put in back in 2012!!!
http://www.hids-direct.co.uk/xtec-38mm-c5w-9-smd-canbus-led-number-plate-bulbs-white/
Still working fine no errors or nothing!!!  :laugh:
Offline Leco_GTI
« Reply #5 on: May 09, 2017, 12:47:07 pm »
I gave up on LED's since the sidelights keep failing. I put some halogen as sidelights to check if they will blow up. If they do then there is a problem with the car and not the lights :(
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: May 09, 2017, 12:59:28 pm »
Almost all mk5 Golfs can fit these OEM LED number plate lights without issues: http://www.carsystems.pl/license-plate-led-1k8943021b,id41.html. They're plug&play.
Some rare cars require a bulb out canceler: http://www.carsystems.pl/license-plate-led-plug-play-adapter,id373.html.
Offline amanda
« Reply #7 on: May 09, 2017, 03:48:24 pm »
I have used this company also not for led's though.
Offline david25
  • -Given: 19
