Author Topic: Metal tyre valve slow leak?  (Read 2181 times)
MPS
« on: May 09, 2017, 08:21:44 pm »
Hi
I have the hollow type Monza 2 wheels with the metal valves. I have a slow leak and I suspect it's coming from the metal valve or one of the o-rings that accompanies it. They're nothing but a PITA and to add insult to injury you can't fit standard rubber valves as they don't fit! How dumb is that?
Anyone else had this issue?
Thanks  :happy2:
Offline strongbow
Re: Metal tyre valve slow leak?
« Reply #1 on: May 09, 2017, 08:40:53 pm »
 yes mate had the same issue, got a couple from vw part no; 1ko-601-361.
also one of my slow air leaks was due to needing the tyre resealed to the rim .
MPS
« Reply #2 on: May 09, 2017, 08:43:58 pm »
Cheers. Robbing barstewards aren't they? They ditched them with the later Ronal manufactured Monza 2s. I just hope they have stayed with rubber valves on the golf R wheels.
Offline Octoparrot
  • -Receive: 102
« Reply #3 on: May 09, 2017, 09:25:27 pm »
I've also got a slow leak that I've always suspected was the metal valve.
Offline david25
  • -Given: 19
« Reply #4 on: May 10, 2017, 05:23:10 pm »
Yes, with the old 17" Monza wheels made by BBS. ALWAYS keep some spares around!
MPS
« Reply #5 on: May 10, 2017, 07:36:28 pm »
Ah, so its not just the 18s that have the metal valves then?
MPS
« Reply #6 on: May 11, 2017, 07:50:25 pm »
Tyre valves usually have a removable inner stem, it should be no different on the metal valves in theory?
Offline Mitch H
  • -Receive: 25
« Reply #7 on: May 11, 2017, 09:15:52 pm »
Do you have a pic of this valve? Think you will be able to replace the whole thing with a standard rubber valve
