Author Topic: B6 Passat alloy hubs  (Read 5380 times)
Offline exodus_ste
« on: May 12, 2017, 01:05:24 pm »
Quick question, when on the lookout for B6 ally hubs does it matter which engine car they are from?
Steve
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: B6 Passat alloy hubs
« Reply #1 on: May 12, 2017, 01:05:55 pm »
No.
Offline exodus_ste
« Reply #2 on: May 12, 2017, 01:48:58 pm »
The perfect answer, thanks  :happy2:
« Reply #3 on: May 12, 2017, 01:57:35 pm »
Ideally get a pair of them from the same seller as they will likely have come off the same car, for consistency.   I didn't fancy a left one from one car and a right one from a different car.
I paid £25 each and they came with bearings, backing plates, ABS sensors and cable/pipe brackets, so ready to bolt on!   Although I am super picky and replaced the wheel bearings on mine!
Offline exodus_ste
« Reply #4 on: May 12, 2017, 04:56:44 pm »
Thats exactly what ive been trying to do Pudding. Trawled through loads recently and trying to find a matching pair that arent covered in hammer rash is tricky. Going to have them shot blasted aswell. Found some SKF wheel bearing assemblies for £50 which i thought was pretty good so im going to do them aswell.  :smiley:
Offline Christiank
  • -Receive: 39
« Reply #5 on: May 12, 2017, 05:12:52 pm »
Sorry for the spam.... Since I'm just a stupid dane who only had english in midleschool  :innocent:
When you write alloy hub it got me interested since hub in my terms of speak is the same as the cap you cover the wheel bolts with on the rim hehe..
And no I'm not a mechanic nor have the skills to play one, that's problerly why I don't know what you guys are talking about here :D
So please do tell so I car learn something new today :D :signLOL:
Offline v4rley
  • -Receive: 104
« Reply #6 on: May 12, 2017, 05:16:16 pm »
Ally weights less than cast  :happy2:
Offline Christiank
  • -Receive: 39
« Reply #7 on: May 12, 2017, 05:45:11 pm »
Yeah I know that the alloy is ligther than the cast iron.
I'm upgrading my own wishbones to B6 alloys instead of the stock mk5 cast iron ones.. That's why the tittle got my interested in the first place ;)
But the "hub" part is where/what on the car?
Offline v4rley
  • -Receive: 104
« Reply #8 on: May 12, 2017, 06:11:26 pm »
The hub is what connects the suspension to your a mentioned wishbone.
Fitted on the 'B6' passsts
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #9 on: May 12, 2017, 11:59:00 pm »
@Christiank
« Last Edit: May 13, 2017, 12:00:51 am by MIJ_JAGGER »
Offline Christiank
  • -Receive: 39
« Reply #10 on: May 13, 2017, 11:37:21 am »
@Christiank
Awesome - Thanks..
I'll go track down some of these for my own car. Now since I'm doing the B6 alloy wishbones I might get these aswell.
Anything to look for or aften when I'll try track down such pairs?
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #11 on: May 13, 2017, 12:48:54 pm »
@Christiank
Awesome - Thanks..
"Ideally get a pair of them from the same seller as they will likely have come off the same car, for consistency.   I didn't fancy a left one from one car and a right one from a different car."
I would do what Pudding mentioned^^^
« Reply #12 on: May 13, 2017, 04:25:00 pm »
Just to see them in the flesh as it were, these are the 'hubs'.  They have other names like 'Bearing housing' and 'Steering knuckle'.
I think you save 4-5kg per side with these hubs and the Passat wishbones.  The cast hubs are super heavy!
exodus_ste - definitely avoid hammered ones!!!  Unlike the cast hubs, you absolutely cannot whack them with a hammer to free off the tie rod end.  Seen people do it and it can f'ck the hub!  Need a proper ball joint splitter  :happy2:
Offline Christiank
  • -Receive: 39
« Reply #13 on: May 13, 2017, 09:24:40 pm »
Great. Maybe you could tell me the part numbers @Pudding?
Do you bought genuine bearings or some aftermarket? Going to put some now ones on mine when I'll have this work done
