Author Topic: Sun visor rattle  (Read 6405 times)
Offline D Squared
  • -Given: 41
Sun visor rattle
« on: May 18, 2017, 06:36:01 pm »
The drivers side visor when up appears (the plastic of the mirror) to be touching the light when closed, and then vibrates - blooming annoying.. anyone else's touch and vibrate?
The light isn't hanging out or anything either..
2007 5dr GTi
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Sun visor rattle
« Reply #1 on: May 18, 2017, 07:50:05 pm »
Never had any trouble with mine, although there's a few I've got that I'd guess aren't as easy a fix...
I'm thinking along the lines of replacing the visor with another from a scrapper/ebay? I'm pretty sure it's straightforward to remove.
You can swap rattles with me if you want - on mine the plastic height adjuster of the driver's seatbelt makes a constant click/creak. Right in my ear!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: May 18, 2017, 08:21:55 pm »
Mine does it, ive got it to sit slightly off the roof lining which has stopped the rattle  :happy2:
Offline D Squared
  • -Given: 41
« Reply #3 on: May 18, 2017, 09:09:02 pm »
Ah ok... mine won't do that, just sits back on light and rattles... it's almost like the light is not in properly or lining hanging down...I may go into dealer and check a few out...
2007 5dr GTi
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: May 21, 2017, 10:30:20 am »
Keep playing with it, should do it eventually  :happy2:
Offline Pirelli_Reece
  • 2008 Pirelli Edition GTI
« Reply #5 on: August 19, 2017, 04:07:34 am »
IIRC there is a TPI for this, there is a packing insert sort of thing that gets put under the vanity light to hold it in. Not sure if that particular TPI applies to your car but even so, that could be a route to explore
Offline D Squared
  • -Given: 41
« Reply #6 on: August 22, 2017, 12:32:21 pm »
Thanks for that...my car is going into VW to get this and a few other little things sorted soon..
2007 5dr GTi
Ethelalant
Sun visor rattle
« Reply #7 on: September 07, 2018, 02:27:36 am »
So is there a fix for this rattle? or is this something you just have to live with? Mines usually happens up until the car is up to operating temperature.
