Author Topic: Old member back with a proper GTI. Help needed with fault codes.  (Read 2118 times)
Offline G40will
Back on the forum again after not having a MK5 for a while.
This was my old TDI
And a few of my new GTI.
I've owned it for a couple of weeks now and really enjoying being a bit more of an enthusiast again and doing some mods on it.
But I have a problem I could use some advice on, I have access to a snap on solus machine and scanned it today after the engine management light came on. Here's a pic of the codes.
Ignore the MAF one that was my fault for not connecting it back up after having the engine cover off.
Any help would be much appreciated.
« Last Edit: May 20, 2017, 08:07:04 pm by G40will »
Offline chimp400
  • -Given: 46
Re: Old member back with a proper GTI. Help needed with fault codes.
« Reply #1 on: May 21, 2017, 05:52:37 pm »
Did you clear them and take it for a run after reconnecting the maf sensor?
« Reply #2 on: May 22, 2017, 04:17:42 pm »
As above.  The other 2 errors go hand in hand with a defective MAF.
Offline G40will
« Reply #3 on: May 22, 2017, 09:17:42 pm »
I cleared them on Saturday and then re scanned the car on Sunday and they hadn't come back so fingers crossed thats all it was.
Thanks for the info.
Offline G40will
« Reply #4 on: June 05, 2017, 05:22:07 pm »
The engine management light came back on today and the only code showing is P2187 again.
The MAF doesn't look genuine. Could this be faulty or possibly the loom?
« Reply #5 on: June 06, 2017, 02:37:01 pm »
It could be the loom if it's complaining about the supply voltage, but it also doesn't sound encouraging if the maf is aftermarket.  Perhaps try a new genuine one first and go from there.
