Author Topic: RNS510 + Fiscon  (Read 1460 times)
Offline xs2man
  • -Given: 18
RNS510 + Fiscon
« on: May 22, 2017, 01:01:46 am »
So I am fitting my RNS 510 and Fiscon Bluetooth into my Edition 30.  My phone wont see the Fiscon to connect to it though.  And I don't yet have a highline cluster in the car to see if ti shows up there.
I was wanting to try to factory reset it, but that wont work without either connecting a phone (which it wont do if it already has 5 connections), or a highline cluster.  Well, as far as I can tell.
Any ideas?  I have enabled telephone with VCDS in the CAN gateway (although I am using a version Q, which I believe comes from a Passat or something).  But in general, I get nothing.
Also, my ipod connection under the arm rest doesn't appear to be working.  Was working fine with my MFD2 before.  Is it not compatible?
Offline xs2man
  • -Given: 18
Re: RNS510 + Fiscon
« Reply #1 on: May 22, 2017, 05:04:03 pm »
Ok,
So after todays outing in the car, I did manage to connect to the Fiscon.  However, I couldn't get anything to show on screen.  When I hit the phone button, all it does is mute the audio.  When I un-mute the audio (by pressing the phone button again), the volume is significantly lower than it was originally.  Any idea why it wouldn't show anything on-screen?
Also, I received a call while driving, and I had to answer it with the phone (luckily on a decent mount), but the microphone didn't work.  Now, I am connected to the Parrot microphone I had initially installed, mostly because it was already run.  But do I need to get a proper Kufatec or VW mic for this system to work?
Also, I notice from some posts that reverse parking sensors, and the climate controls can appear on the RNS 510 screen.  Is this possible with the standard mk5 equipment?  Or do I need to move up to mk6 components?  If mk5 will work, how would I go about getting that to work?
