Author Topic: 2005 VW GTI, odometer screen mileage fault  (Read 4357 times)
Offline Imz26
« on: May 22, 2017, 05:21:58 pm »
Hi, recently got a vw golf gti 2005.
Car was standing for around 1 day in the sun, switched the car to find the mileage has faded and i can just about see it. Mileage still clocks up as normal on driving. The rest of the screen time/mpg etc is fine just mileage part at bottom is disappearing.
Any advice would be highly appreciated.
willni
Re: 2005 VW GTI, odometer screen mileage fault
« Reply #1 on: May 22, 2017, 09:50:51 pm »
Check the battery charge, it generally fades there with low battery but the rest doesn't
Offline Imz26
« Reply #2 on: May 23, 2017, 02:08:10 am »
How do i check battery charge car has been standing for around a week but does get started up every day or two
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: May 23, 2017, 07:30:50 am »
Very common on midline clocks, best to upgrade them to highline ones.
Sent from my SM-G928F using Tapatalk
Offline xjay1337
  • -Receive: 377
« Reply #4 on: May 23, 2017, 10:05:50 am »
Nothing at all to do with the battery. How does that even make sense? it's all powered from the same bleedin circuit.
Just an old / failing display. Upgrade the dash cluster.
Offline SiimpleHarry
« Reply #5 on: May 23, 2017, 12:50:50 pm »
I've had this before, first noticed it when I hit 100k so I thought it was due to the new lights activating for the extra digit. Slight fading for the first 3 numbers but it soon sorted itself out without doing anything.
Offline ReflexRob
« Reply #6 on: May 23, 2017, 01:16:37 pm »
It is very common and happens in hot weather only....
Offline andy7ven
  • -Receive: 30
« Reply #7 on: May 23, 2017, 05:48:33 pm »
This... Same as mine bottom part goes faint, but sharp as anything when temperatures drop again...
Offline Imz26
« Reply #8 on: May 24, 2017, 12:00:43 pm »
Yes i was told it was due to the car directly facing the sun. I faced the front of the car towards a wall and went to start car after a day and it was back to normal. Asked a local car electrican he said due to heat melting the liquid crystals in display and to leave window open a little in heat. Also said £100 labour to change cluster due to it being connected to immobiliser and about £50 for cluster.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: May 24, 2017, 01:07:20 pm »
Get a cluster for £50 midline or £100 - 150 for a highline, Bring it to me and I can code it for £40.
Drop me a PM if you need more information
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #10 on: May 24, 2017, 01:34:00 pm »
I have a 973 highline for sale if interested
