Author Topic: Stereo Upgrade  (Read 9138 times)
Offline shaunK
Stereo Upgrade
« on: May 25, 2017, 10:58:31 pm »
Wondering if anyone cold help/advise.
I've just bought a 2005 GTI and it has this installed with a 6 disc changer in the armrest although that throws up an error and will not work.
I'd like to change it for something (VW preferable) that would except a SD card and poss phone connection although not sure if I'd have to install a microphone??
If someone could advise that'd be great
Offline xs2man
  • -Given: 18
Re: Stereo Upgrade
« Reply #1 on: May 26, 2017, 12:15:13 am »
RNS315 is the obvious upgrade from there.  You should get a DAB one for around £300.  Has built in Bluetooth, so that's a bonus.  Should do everything you are looking for.
Alternatively, RNS510.  It's the top one, but doesn't have BT.  You need a new one for DAB too, so around £400.  For BT you can either go for a Fiscon or Parrot.  OEM is too expensive usually.
Either way, you will likely need a new CAN Gateway.  Usually around £50 coded, or you can pick them up for £30 or so on ebay and code yourself.
If you are happy enough with the nav system (easy enough to upgrade firmware, apply "crack" and burn latest maps), you could just add a Parrot system, letting you get your BT, USB, SD + Ipod.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: Stereo Upgrade
« Reply #2 on: May 26, 2017, 09:25:33 am »
I fit one of those cheap Chinese Bluetooth adapters to that stereo on mine the other day, works perfectly for audio streaming
Offline shaunK
Re: Stereo Upgrade
« Reply #3 on: May 26, 2017, 10:39:34 am »
Don't suppose you have a link from where you got it from do you?
Offline shaunK
Re: Stereo Upgrade
« Reply #4 on: July 04, 2017, 10:09:33 pm »
After reading another post on here I'm temped to purchase one of these
https://www.aliexpress.com/store/product/Car-6-5-MIB-UI-Radio-RCD510-RCN210-RCD330-RCD330G-Plus-For-Golf-5-6-Jetta/523203_32722343695.html?spm=2114.12010612.0.0.mJU6tB
which would give me all the feature I'm after. I take it I'd also have to upgrade the CAN Bus with this as I have a 2005 car?
Anyone have any experience or purchased one of these?
