Author Topic: Whooshing sound after fitting a new rev G diverter valve  (Read 1525 times)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« on: May 28, 2017, 12:40:14 pm »
Hi all I've replaced my DV as I thought the old one was a rev D, after removing it transpired to be the G version.
I replaced it anyway as I had already bought a new G version; however I am now getting the whooshing sound under acceleration.
Is this normal or is something not quite right?
Black Ed30
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: Whooshing sound after fitting a new rev G diverter valve
« Reply #1 on: May 28, 2017, 02:06:45 pm »
Did you make sure you did everything up tight? And it was all flush?
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #2 on: May 28, 2017, 02:22:13 pm »
Yeah I'll have another look pretty sure I did it's only three screws
Black Ed30
Offline Shamm
« Reply #3 on: May 28, 2017, 03:41:39 pm »
Maybe youve solved the dv issue and got a boost leak elseswhere? Maybe
Offline Chris92
  • -Given: 33
« Reply #4 on: May 29, 2017, 12:55:58 pm »
There's a little notch/pin thing on the DV so it'll only sit flush one way, maybes you haven't aligned the pin with the slot in the housing? Not sure if it wasn't lined up if the other bolt holes would line up but just a idea
Offline Mk5. EWC
« Reply #5 on: May 29, 2017, 09:00:34 pm »
Do you have standard intake?
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #6 on: May 29, 2017, 09:39:23 pm »
It's all sorted I removed the bolts and retightened them and all is fine now thanks
Black Ed30
