Author Topic: Oil pressure gauge  (Read 9476 times)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Oil pressure gauge
« Reply #1 on: May 30, 2017, 08:16:43 am »
First of all the sender will need to match the scale of your gauge. Most gauges will come with a suitable sensor if its a digital one
Secondly you need a way of plumbing it in to the engine. There isn't simply a spare hole to just screw that 1/8 NPT fitting in to. You'll need a T or Y fitting to tap in to the oil pressure switch location, and be sure to check what thread the car * standard pressure switch uses as it may not be 1/8 NPT.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: May 30, 2017, 09:28:55 am »
Thanks @Dan_FR thought it wasn't as simple as plug and play  :doh:
 :drinking:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #4 on: June 02, 2017, 11:13:42 pm »
You need something that can 'T' in to the oil pressure switch.. What you've linked won't work.... From memory the car side is M10 x 1mm so you will need something like this: http://www.ebay.co.uk/itm/Remote-Oil-Pressure-Gauge-T-Piece-M10x1-0-VW-Audi-Seat-Skoda-Etc-095-5-/282498230187?hash=item41c634e7ab:g:MjkAAOSwxg5XxZQz
But you will need to check the threads are correct
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: June 02, 2017, 11:23:19 pm »
Thanks mate, didn't think it would be this difficult and I'm sure I'll have to tap a hole into the sump for this?.
Is it worth having the oil pressure gauge?
« Last Edit: June 03, 2017, 03:22:13 am by r5gtt »
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: June 03, 2017, 05:23:29 am »
You can't tap in to the sump for oil pressure
You don't need to drill anything, you just need access to the oil pressure which is done by going through the oil pressure switch location.
Offline ducman77
  • -Given: 59
« Reply #7 on: June 03, 2017, 08:14:30 am »
Good luck with this buddy!
Will be watching with interest as I would love an oil pressure gauge on my car too :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: June 03, 2017, 02:30:14 pm »
:doh: hahaha  :stupid: sheeeeeet of paper  :signLOL: thanks mate would have been a balls up right there!!!  :surprised:
That's going to be a mission as the sensor is in an awkward place on the gti but we'll see  :happy2:
Thanks again for your help and advise  :smiley:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: June 03, 2017, 02:36:50 pm »
Lets hope I don't mess anything up  :doh:
« Last Edit: June 03, 2017, 03:29:06 pm by r5gtt »
Offline ducman77
  • -Given: 59
« Reply #10 on: June 03, 2017, 02:57:49 pm »
I have faith in you buddy  :smiley: :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: June 03, 2017, 03:44:33 pm »
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #12 on: June 08, 2017, 03:14:12 pm »
« Reply #13 on: June 08, 2017, 04:04:05 pm »
Having done this before, I'd say it's not worth the agro!  But if you want to do it, it is indeed M10x1 fittings as Dan said.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: June 08, 2017, 05:17:41 pm »
This might be slightly easier @r5gtt
https://www.awesomegti.com/shop-by-brand/newsouth-performance/newsouth-2-0t-fsi-banjoport/
Thanks Dan, is it worth doing to keep an eye on pressure?. Need something to fill the third pod hole lol
looked at the location of the pressure switch and it doesn't look like a 5 minute job that's for sure  :doh:
nope never done this before but as above I wanted to fill in the void and also is it worth doing?
