Author Topic: Bwa engine thermostat replaced now fans running hard  (Read 5204 times)
Offline Dan1290
« on: May 30, 2017, 09:13:01 pm »
Good evening folks recently changed my thermostat for a genuine one as I wasn't hitting 90 on dash.. Now I'm rock solid 90 but when I switch car off and remove key the fans come on flat out for 50 seconds.. Torque app says coolant is at 103 everywhere I go now aswell is this normal?
Offline Richie-VRS
Re: Bwa engine thermostat replaced now fans running hard
« Reply #1 on: May 30, 2017, 11:16:17 pm »
Did you definetly plug in the wee temp sensor on the stat? you may have an air lock if the system hasn't bled properly.
Offline Dan1290
« Reply #2 on: May 30, 2017, 11:45:57 pm »
There wasn't a sensor on the stat? I did remove the intake to fit,  which sensor could cause this high reading? Also how do you bleed the system?
Offline 99hagued
« Reply #3 on: May 30, 2017, 11:50:19 pm »
U sure it's not the ac fan, mine carries on running for a few seconds after turning the engine off when I'm using the ac
Offline Dan1290
« Reply #4 on: May 30, 2017, 11:52:23 pm »
Yes ac is off and it is still comes on once switched off
Offline 99hagued
« Reply #5 on: May 30, 2017, 11:58:36 pm »
The systems should be self bleeding, when it's up to temp feel both radiator pipes see it there both hot if so must be a sensor problem. This on a mk5 gti?
Offline Dan1290
« Reply #6 on: May 31, 2017, 12:00:22 am »
Yes mk 5 gti bwa engine.. Thanks for for your input mate.. Dying to get to the bottom of the it.. Do you know what where all of the sensors are?
Offline 99hagued
« Reply #7 on: May 31, 2017, 12:17:49 am »
Not too sure to be honest mate. I remember when I did my main thermostat there was a sensor on that and I think there's one on the right hand side of the engine (if you were stood facing the engine)
Offline Dan1290
« Reply #8 on: May 31, 2017, 12:32:17 am »
Ok cheers mate in the so some research online
Offline Richie-VRS
« Reply #9 on: May 31, 2017, 12:43:27 pm »
The coolant is self bleeding to a point but you need to put the heater on full heat and hold the revs at 2500rpm until the fan kicks in (above 90c) with the cap off. Keep checking the coolant level and keep it topped up.
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« Reply #10 on: May 31, 2017, 06:17:44 pm »
Good practice to renew Your temperature sensor located on the side of the block underneath the intake pipe and your small fan might of had it mine did and it sounded like a jumbo jet taking off after shutting down the engine
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline Dan1290
« Reply #11 on: May 31, 2017, 07:08:53 pm »
Thanks mate which is the main temp sensor? The one on the end of the engine above gearbox or below thermostat housing?
Offline Wolf Burger
« Reply #12 on: May 31, 2017, 10:09:01 pm »
My 07 Mk5 GTI had the exact same problem after a main thermostat change.
was changed because of the temp stat not being at a standard 90.
after the change, the big fan used to run at turn off for ages. Really annoying.
Never solved TBH
(This post really doesn't help the OP)
Golf Mk6R 2011- Rising Blue- Manual-
Modifications-
E-Tuners 361 BHP - 350lbs
Revo Intake
Bilstein B16 & H&R ARB's
Team Dynamics 1.3
18Z Porsche BBK
RNS510 with Focal Speaker upgrade
MK6 Recaro Heated Buckets
Cruise Control
Highline Reverse Camera
Offline jhook661
  • -Receive: 20
Offline Dan1290
« Reply #14 on: May 31, 2017, 10:24:31 pm »
Never solved TBH
Mate trying hard to solve this have you replaced your temp senders?
