Author Topic: Air con sensor  (Read 1858 times)
Offline neiller
  • -Given: 32
Air con sensor
« on: June 01, 2017, 04:59:54 pm »
Can any1 give me the Vw part number of the air con sensor just below the alternator ?
I've got a leak and need to replace it .
Is there an easy way to unscrew it?
Offline SI-R32
  • -Receive: 125
Re: Air con sensor
« Reply #1 on: June 01, 2017, 05:11:43 pm »
It will have the number written on it if you look closely
Offline neiller
  • -Given: 32
Re: Air con sensor
« Reply #2 on: June 01, 2017, 05:12:24 pm »
I know but I want to have one to replace it when I take it out!
Offline Christiank
  • -Receive: 39
Re: Air con sensor
« Reply #3 on: June 01, 2017, 08:09:53 pm »
It's the "High Pressure Sensor" ... Partnumber should be: 5K0959126 and the O-ring has partnumber: 8E0260749
I know since I'm about to replace mine also.. No easy way to unscrew, I nearly broke my hand the other day and after that I nearly broke the motor :D .. So I'll be changing mine when I'm having the entire front end off to do the GTI frontbumper conversion.
Offline neiller
  • -Given: 32
Re: Air con sensor
« Reply #4 on: June 01, 2017, 09:15:08 pm »
Offline Sung
Re: Air con sensor
« Reply #5 on: June 01, 2017, 09:27:00 pm »
Easy job takes 5 mins with the correct tools. Crows foot is what you need  :happy2:
Offline neilw
Re: Air con sensor
« Reply #6 on: June 01, 2017, 10:48:17 pm »
Changed mine recently, the new design is much easier to put on as a 24mm deep socket will go over the top of the electrical connection.
5K0959126 was the part number I put in according to my records.
Old one came off fairly easily with a 17mm crowsfoot spanner
Sent from my SM-J510FN using Tapatalk
« Last Edit: June 01, 2017, 10:52:29 pm by neilw »
Edition30 #0002 R-Tech Stage2
