Author Topic: Retrofitted a reverse camera  (Read 7322 times)
Offline Jmccarron71
  • My Ride: Edition 30 stage 2 bcs power valve
« on: June 01, 2017, 09:10:35 pm »
Hi I've just retrofitted a reverse camera kit on my mk7 gtd non sat nav but I assume that doesn't make any difference.But it all went pear shaped when I tried to activate with vcds.it would appear it doesn't support my car.Ive ordered a more up to date vcds on eBay .Has anybody successfully done this?Was a genuine vw retrofit kit I got so fingers crossed.
Offline Wolf Burger
Re: Retrofitted a reverse camera
« Reply #1 on: June 01, 2017, 09:22:22 pm »
What car model is the camera from?
What model is your car?
I had the same problem fitting a highline camera from a Passat to my 6R
Had to change the model in VCDS to Passat. It now works
Golf Mk6R 2011- Rising Blue- Manual-
Modifications-
E-Tuners 361 BHP - 350lbs
Revo Intake
Bilstein B16 & H&R ARB's
Team Dynamics 1.3
18Z Porsche BBK
RNS510 with Focal Speaker upgrade
MK6 Recaro Heated Buckets
Cruise Control
Highline Reverse Camera
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #2 on: June 01, 2017, 10:46:34 pm »
On the Golf Mk 7 the reverse camera will only work with certain head units.
Take a look here:
http://www.carsystems.pl/golf-7-rvc,tag.html
  • -Receive: 427
« Reply #3 on: June 01, 2017, 11:33:19 pm »
@Jmccarron71
Assume you've posted this is VWROC? Know of a few peeps over there who have retrofitted RVC to their Mk7 but can't remember which Headunit they have. I'll have a look.
Offline Jmccarron71
« Reply #4 on: June 02, 2017, 10:08:56 pm »
Will have to remove media unit and check part number.new vcds software should be here soon .will let you know how I get on.
Offline Jmccarron71
« Reply #5 on: June 07, 2017, 05:57:13 pm »
My vag number on ecu is 5g0 035 820a so according to that link is not compatible with my new camera lol.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #6 on: June 09, 2017, 10:37:23 pm »
Rev cam works on Discover Media and Discover Pro. Your one is composition so nope
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Jmccarron71
« Reply #7 on: August 10, 2017, 08:40:09 pm »
I finally got my reverse camera to work .i bought a kenwood / garmin sat nav retrofit kit and was able to wire in my vw camera into it and now working fine plus I've got sat nav.
