Author Topic: Timing issue  (Read 1147 times)
Offline matty_d
Timing issue
« on: June 02, 2017, 02:33:33 pm »
Hi,
Having a few issues with my gti that I have just purchased 2 weeks ago. Had the cam belt and chain tensioner replaced. The mechanic is absolutely certain that the timing is all bang on yet he is saying that it is popping up with warnings saying that there is a timing fault.
I rang the garage that I bought it from and they said that old warnings can still pop up on the computer and it's nothing to worry about.
Is this plausible? The car was driving ok to be fair?
Matt
Offline Pesky jones
Re: Timing issue
« Reply #1 on: June 07, 2017, 09:47:44 pm »
Have you got access to vcds
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Timing issue
« Reply #2 on: June 08, 2017, 07:28:07 am »
Clear codes... if it comes back or won't go away then there's a fault. Don't let them fob you off
Idealy you'll want it on VCDS as already said to make absolutely sure the cam timing is spot on..... so easy to get it a tooth out
Re: Timing issue
« Reply #3 on: June 08, 2017, 09:30:31 am »
MK5 or MK6?  If MK5, why only the chain tensioner and not the chain as well?
