Author Topic: 2.0T Gti AXX 2005 ruff running when warm  (Read 1233 times)
Offline DBXdarkangel
  • -Given: 18
« on: June 03, 2017, 09:52:08 pm »
Hey guys as the title says. When my car geta warm ive noticed it rumbles slighty like a coil pack or plug. When ita cold its perfectly fine and theres no fault codes on vag-com.
Also when ita cold ive noticed it sticks in gear very slightly and when i set off i can feel from the pedal a slight thumping like a intermittent thumping. When i accelerate and my clutch foot is resting on the clutch pedal, as i lift off the gas i can feel the clutch pedal slightly dip. Weird?
Offline barelyrelevant
Re: 2.0T Gti AXX 2005 ruff running when warm
« Reply #1 on: June 04, 2017, 10:08:06 pm »
As you said could be a coil pack on the way out, wouldn't throw a fault code.
Mine did that for a couple of weeks and then the coil failed completely.
  • -Given: 18
« Reply #2 on: June 05, 2017, 09:30:39 am »
How can i test a coil pack tho as it only does it when warm.
« Reply #3 on: June 08, 2017, 11:57:13 pm »
Don't know i'm afraid, when it does go completely it will throw a code relating to the cylinder it has failed on. You can then clear the codes, swap the coils and see if the code moves across to a different cylinder to diagnose.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #4 on: June 09, 2017, 07:47:24 am »
Coil packs generally show up under load (i.e. boosting around)
  • -Given: 18
« Reply #5 on: June 09, 2017, 08:47:45 am »
Any ideas on my gear / clutch issue?
