October 03, 2024, 09:33:26 pm
All Things Mk5
Mk5 General Area
Aux cable for the standard radio
Topic: Aux cable for the standard radio (Read 2106 times)
Rossmk5gti
Taking part
-Given: 5
-Receive: 1
June 05, 2017, 05:58:11 pm »
Was just wondering if I needed to remove the coin holder to wire in an aux or could I use something like a coat hanger to guide it to the area where the radio is??
Sent from my SM-G935F using Tapatalk
Golfmk5GTD
Taking part
-Given: 0
-Receive: 4
Re: Aux cable for the standard radio
Reply #1 on:
June 05, 2017, 07:49:15 pm »
In all honesty Ross you're best off following a how to guide to remove the stereo and have a play around. Try running the aux cable from the back of the stereo to down there. However the trim is very tight towards the coin holder area.
It would be best to experiment and sure sure the wire isn't covering any retaining clips etc.
r5gtt
Just look at my post count
-Given: 342
-Receive: 334
Reply #2 on:
June 05, 2017, 08:01:00 pm »
Can you not remove the side panel off the centre console to route the wiring down to the coin holder?. You will have to remove the stereo either way to plug the wiring into the back of the stereo unit.
MIJ_JAGGER
Won't Shut up.
-Given: 103
-Receive: 78
Reply #3 on:
June 05, 2017, 09:48:00 pm »
Remove the tray it's a piece of wee, pull up on the gear surround, remove 2 screws and bobs your uncle @Rossmk5gti
Rossmk5gti
Taking part
-Given: 5
-Receive: 1
Reply #4 on:
June 07, 2017, 09:33:45 am »
Thank you both of you :)
Rossmk5gti
Taking part
-Given: 5
-Receive: 1
Reply #5 on:
June 07, 2017, 09:34:30 am »
*all three of you
All Things Mk5
Mk5 General Area
