Author Topic: A/C  (Read 2242 times)
Offline Prewy
A/C
« on: June 06, 2017, 02:54:57 pm »
My climate control stays on all the time generally around 22 degrees, during a recent warm spell I turned down to low. It was my wife who pointed out that the air was far from cold especially compared to her car. My question is before I take to garage is this likely to be just I need of a re gas or are there any signs and symptoms for a possible compressor fault? Car is 2007 07 60k. Cheers
Re: A/C
« Reply #1 on: June 06, 2017, 03:37:50 pm »
First step is a fault code scan.  One of the pressure switches are common for going, I can't remember if it's the high or low side one that goes.
Best case scenarios are a knackered condenser, needs a regas or has a gas leak.  Worst case is a knackered pump, but usually you would know about that as they make a lot of noise, or shred belts etc.
Offline Prewy
Re: A/C
« Reply #2 on: June 09, 2017, 08:46:32 pm »
Cheers Pudding, got it booked in next week fingers crossed for the re gas!
Offline DBXdarkangel
  • -Given: 18
Re: A/C
« Reply #3 on: June 09, 2017, 09:02:45 pm »
Might sound obvious but the Air con works when the ac light is OFF on the dial. I mistakenly thought mine wasnt working as when i pressed the dial and the light was on, i assumed that ment it was activated. When i pressed it again so the ac light was off, the cold air came through.. backwards i know.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: A/C
« Reply #4 on: June 09, 2017, 09:57:38 pm »
Never seen that before. My A/C comes on when you press the A/C button and it illuminates.
Offline Sung
Re: A/C
« Reply #5 on: June 09, 2017, 10:30:57 pm »
Earlier golfs had the eCon button, short for economy. Turn it on (illuminated)and it switches the AC off. No light = AC on. Later models had the AC button.
Offline slix
  • -Receive: 38
Re: A/C
« Reply #6 on: June 09, 2017, 10:51:57 pm »
Oh I was just confused as he said the AC light and not the econ button.
  • -Given: 18
Re: A/C
« Reply #7 on: June 10, 2017, 09:23:00 am »
Sorry i ment econ (air con)
