Author Topic: S3/R engine swap.  (Read 2174 times)
Offline Richie-VRS
S3/R engine swap.
« on: June 11, 2017, 08:24:02 am »
Good morning. I'm toying with the idea of selling my new turbo, injectors and all the bits I've gathered up for doing my k04 swap and just buying a complete engine with turbo and injectors.
Can anyone tell me the engine codes that drop straight in and more importantly will run with my existing BWA loom.
I assume a CJX from a '13-'16 Golf R will not work with my Ecu? I did some reading last night and couldn't find an answer to that specific question.
The only swaps I really seen were talking about CDL and BWJ codes.
Richie.
« Last Edit: June 11, 2017, 08:42:18 am by Richie-VRS »
Re: S3/R engine swap.
« Reply #1 on: June 26, 2017, 12:11:25 pm »
BYD, CDL & CCZ are the most common ones I believe.  You will need to extend the diverter valve loom over to the front of the engine, but otherwise it should be the same.  I believe the ECUs are the same, just different maps, but someone else may be able to confirm.
Offline Richie-VRS
« Reply #2 on: June 26, 2017, 06:46:40 pm »
Cheers pudding, things have now changed somewhat, on Saturday I'm going to pick up an AXX engine, I have just been delivered s3 rods and pistons so I'll be rebuilding the AXX with them and new rings etc.
