Author Topic: Electric windows and central locking  (Read 4993 times)
Offline Gti_enthu
« on: June 11, 2017, 04:45:55 pm »
Hi guys as I posted a while back I was having issues with my electric windows. I have since managed to make the passenger front window work and have come to the conclusion the rear window motors are faulty, do these have part numbers or do any mk5 golf gti motors for? My fuel cap button on the drivers door still doesn't work and that's peeing me off a bit. And finally I know have central locking issues. Have to manually lock/unlock the car and sometimes this sets the alarm off. I have had a friend connect a diagnostic machine and the only fault was a blown bulb. Any ideas?
Thanks in advance
Offline SI-R32
  • -Receive: 125
Re: Electric windows and central locking
« Reply #1 on: June 12, 2017, 10:48:07 am »
Some of the cables in the drivers door rubber boot (where the door swings open) will be broken, 99% sure it'll be that.
Offline Gti_enthu
« Reply #2 on: June 12, 2017, 05:02:46 pm »
@SI-R32 hi mate. I have already stripped the wiring back and everything is fine. There's no loose wires or splits anywhere. Plus the stealers want £105+vat for a new loom
Offline SI-R32
  • -Receive: 125
« Reply #3 on: June 12, 2017, 06:50:45 pm »
ok so i have a few questions, when you manually lock and unlock the car does it do all the other locks or just the drivers door?
when the drivers door is closed does the door open symbol show up and similarly when the door is open does it show up.
what age is your car
whats wrong with back windows want more info
does your driver window retain the one touch function or does it loose memory regularly
when you checked the wires in the door rubber did you feel and bend them one by one as the copper could be broken inside the insulation
cheers
Offline Gti_enthu
« Reply #4 on: June 14, 2017, 02:13:12 pm »
@SI-R32
All the doors lock manually but only drivers door unlocks manually
My car is 2007 57plate
The rear windows don't work at all from the drivers door or each individual door
The window retains one touch at all times
I did not bend the wires just checked for loose connections or rips in the wires
Offline SI-R32
  • -Receive: 125
« Reply #5 on: June 14, 2017, 03:49:15 pm »
OK you say you had it scanned? There was no faults at all?
Just out of interest where you based roughly
Offline Gti_enthu
« Reply #6 on: June 14, 2017, 04:25:39 pm »
@SI-R32 yep had it scanned and the garage chap said no codes apart from a blown bulb. I'm based in Leicester
Offline SI-R32
  • -Receive: 125
« Reply #7 on: June 14, 2017, 10:51:49 pm »
Sadly my friend without being with the car to fault find I'm kinda out of ideas.
I wish you were a bit closer as  I'd off to help you out for free to get it sorted, sorry I can't be of anymore help.
Offline Gti_enthu
« Reply #8 on: June 14, 2017, 11:31:20 pm »
@SI-R32 no probs mate u have been enough help. I need to change my speakers on the weekend as the drivers is popped so I will check the look throughly. Will update u over the weekend
Offline SI-R32
  • -Receive: 125
« Reply #9 on: June 14, 2017, 11:45:30 pm »
just one more thing I should have asked, have you changed anything, worked on anything, had anyone tinkering with the car? especially in the doors?
just in case?
Offline Gti_enthu
« Reply #10 on: June 15, 2017, 12:49:25 am »
@SI-R32 no mate I brought the car as it is. The day I got it it was raining so didn't check all windows and noticed fuel cap wouldn't open but assumed it was a fuse. That still doesn't open by the way.
Offline Gti_enthu
« Reply #11 on: June 17, 2017, 08:22:34 am »
@SI-R32 hi mate just a quick one to pick your brain... the rear electric window motor would I need to replace with the exact same part number?
