It's cool.. found out the info I needed.. all it was info.. no big deal. It's not classified info...
you're totally right its not classified info, most people use AVDI from Abrites which can cost in the region of a grand, if your speedo hasn't got any mileage in it or has been reset to zero you might be able to use VAS 5054A with an online Geko connection to VW which you can pay for by the hour I believe.
But the best news for us all is the fact there are some leads coming out of china that sound remarkably like "AVDI" and can be relativity cheap ish 150 to 300 for depending on which software you want. if you want links to it please ask via PVT message and I'll point you in the right direction.
You can program the key chip up and do all sorts with it, I'll be learning all about this over the coming months as I've just got the software and will be learning what to do with the aid of the AVDI German forum.
all the immobiliser chips and the software are available from Aliexpress.
one of the best things about it, it has an MK60EC1 coding helper built in which is worth its weight in gold to all the people that want to retro fit PLA 1/1.5/2 to older cars needing there brake unit upgraded.
