Author Topic: Android RNS Clone - Aerial Fakra Question  (Read 1658 times)
Offline Broomy
  • -Given: 18
« on: June 18, 2017, 07:04:10 pm »
Just fitted a RNS Clone to the car yesterday but zero radio signal. Seems to be 3 aerial cables. White head, brown and blue. The unit only has one connection.
From some searches I've gathered it's a diversity aerial with 2 feeds.
Will a double fakra adapter cure this or do I need to have the blue cable soldered to provide a 12v feed?
Offline spicypixel
Re: Android RNS Clone - Aerial Fakra Question
« Reply #1 on: June 18, 2017, 08:08:25 pm »
I got in contact with celsus and they've fired back an email with the following suggestion:
https://www.driveden.com/car-audio-tech-c188/leads-fittings-c300/dual-fakra-with-diversity-to-din-aerial-adaptor-p79539
https://www.driveden.com/car-audio-tech-c188/leads-fittings-c300/female-fakra-to-female-din-aerial-adaptor-p79552
They suggested the pair of these connected via the DIN.
I'm debating ordering the pair to connect my diversity antenna to the single FAKRA input too. Though I don't have an amplified version so no 12v to consider...
Mk5 GT TDI 170 - MY2007
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #2 on: June 22, 2017, 01:20:45 pm »
Wouldn't put 12V near any aerial connections  :scared:
Blue is Sat Nav so ignore for radio
White and brown are FM / AM connections
One roof & other rear glass
They go to diversity under drivers seat.
Get double male each end to bypass this and disconnect power
behind radio -  get two to single adaptor
Any adaptor with a 12V feed and canister, would avoid.  just a gimmick
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
