Author Topic: Bad misfire, help needed!  (Read 1180 times)
Offline GTI_Kyle
« on: June 19, 2017, 10:06:33 am »
Need some help with a bad misfire on my stg2+ FL Leon cupra has developed. It starts ok but sounds really rough with a constant misfire, almost like a Scooby sound. It's in limp mode aswel with the EML flashing sometimes, plugged it in with my basic scanner & it come up as a misfire on cylinder 4 P0304 code.
Changed coilpacks & spark plugs but still same. I suspect maybe a bad injector or bent valves?
Anyone else had this problem?
Stage 2 Graphite Blue DSG GTi - Too many mods to list...
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Bad misfire, help needed!
« Reply #1 on: June 19, 2017, 10:08:46 am »
Very common, will be a duff injector..... Get someone with VCDS to look at the misfire to check its only that cylinder and that its a regual idle misfire that will probably clear up once revved..
Once confirmed, get it sorted ASAP and don't drive it about hard at all, as its a potential engine killer
Offline GTI_Kyle
« Reply #2 on: June 19, 2017, 10:20:32 am »
I had to limp it home but barely went over 25/30mph due to being so down on power. Hopefully it is just an injector and not bent valves!
Is there any particular reason why injectors give up?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #3 on: June 19, 2017, 10:39:36 am »
Common issue on the K04 engine cars....  Could just be carbon build up - ideally all 4 need to be tested and balanced.... R-tech offer this, whether you just send them your injectors or book in to have it all done for you
Offline GTI_Kyle
« Reply #4 on: June 19, 2017, 10:57:08 am »
I've had the inlet cleaned & RFD fitted recently mate so won't be carbon build up. Might consider sending them off once the problems diagnosed.
Is there any differences in symptoms with a bad injector & a bent valve?
Offline GTI_Kyle
« Reply #5 on: June 19, 2017, 01:04:44 pm »
Update - compression test done & there is no compression on cylinder 4. Other cylinders are fine.
Once the heads off will have a better idea what the problem is...
