Author Topic: Intake Manifold Runner Control P3138 fault  (Read 17262 times)
Offline jacobrownoly
« on: June 20, 2017, 10:39:32 pm »
Hello,
Give the car a scan on VAGcom tonight. The only fault that showed up was Intake Manifold Runner Control P3138
I had a wee look on here and did a reset on block 142 Intake Manifold runner from the ross-tech website. I then re-scanned the car and the fault was still there.
The car feels and goes great still but how can I fix this problem? what does this mean?
Thanks.
Offline sanj
  • -Given: 17
Re: Intake Manifold Runner Control P3138 fault
« Reply #1 on: June 20, 2017, 11:28:31 pm »
Had this problem on my old Edition 30 only thing after trying to get it calibrated was it came back again, there was a slight loss in power. Had to replace the entire part which is a pain in the backside to fit.
« Reply #2 on: June 21, 2017, 12:09:30 am »
Do you have a part number for it? Was it costly??
« Reply #3 on: June 21, 2017, 09:37:08 am »
 Anyone else?
Offline Paradox1
  • -Given: 41
« Reply #4 on: June 21, 2017, 12:14:34 pm »
A new manifold is about 400quid alone. Plus a new gasket and injector fitting kits. Then labour ontop of that if your not doing the work yourself
« Reply #5 on: June 21, 2017, 01:32:40 pm »
Is this gonna be the only way to fix this problem??
« Reply #6 on: June 21, 2017, 01:37:06 pm »
Please correct me if I am wrong but I have found this on eBay, is this what I need?
http://m.ebay.co.uk/itm/292139232098?_trksid=p2385738.m2548.l4275&_mwBanner=1
Offline Paradox1
  • -Given: 41
« Reply #7 on: June 21, 2017, 03:05:46 pm »
its looks correct but no telling that 1 isnt knackered too.
« Reply #8 on: June 21, 2017, 06:13:42 pm »
Just got quoted £360 from TPS :(
Would it be worth checking any sensors that may have thrown the fault up first??
Offline Paradox1
  • -Given: 41
« Reply #9 on: June 22, 2017, 12:13:56 pm »
The sensors are part of the manifold (cant be removed)
usual problems is the sensors fail or the runner flaps fail and dont open properly.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #10 on: June 22, 2017, 01:59:27 pm »
That fault code could be caused by the motor, the linkage or the actual runner flap assembly itself.... A new manifold MAY NOT fix the issue
Fit an RFD, bin off the motor.... job done and headache gone permanently....  :signLOL:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #11 on: June 22, 2017, 02:01:22 pm »
What sensor are you referring to?
« Reply #12 on: June 23, 2017, 12:30:14 am »
Sorry what's an RFD? Do you have a link to how I can get one/how it works? Cost? Etc thanks
The car seems to still be going really well so surly it can't be too serious
Offline Leco_GTI
« Reply #13 on: June 25, 2017, 12:48:59 am »
RFD=Runner Flap Delete. Have a look on the forum or on internet.
I thought my car was running fine until a faulty manifold motor was replaced. After that I thought: wow... those flaps DO make a difference in performance if they are not working correctly. Unfortunately my manifold developed another problem but not sure what it is yet. So far the car is running "fine".
« Reply #14 on: June 25, 2017, 02:50:52 pm »
Thanks for that!
Not really interested in the RFD...especially since you have to change/tweed maps too.
If I need to I will just order a new one from tps. I have cleared the code and done a basic reset again. I will check again in another 50 so miles.
I really don't think it is effecting the cars performance. It still has the same punch as I can't remember.
I will keep this posted!
