Author Topic: Intake Manifold Runner Control P3138 fault  (Read 16833 times)
Offline jacobrownoly
Re: Intake Manifold Runner Control P3138 fault
« Reply #15 on: June 25, 2017, 08:41:39 pm »
So logged the car tonight and everything seems normal.
Boost, air mass intake, lambda, fuel rail, cylinder knock. All seemed normal. :stupid:
Any thing I should log to show up a weakness/ issue in regards to this runner flap fault?
Offline Leco_GTI
« Reply #16 on: June 25, 2017, 10:45:44 pm »
Mine showed up a code but I don't remember anymore and the problem is still there. The intake seems to be problematic on those cars and any repair or replacement it's costly if you are not doing yourself. I guess if the flaps are not opening/closing properly or if they are stuck at some position you would have a code stored in the ECU. With regards logging, I will leave the experts to advise you. What I said is based on my own experience with the bloody intake.
« Last Edit: June 26, 2017, 03:22:38 pm by Leco_GTI »
« Reply #17 on: June 30, 2017, 09:35:58 pm »
Quick update - Cleared the code over 60 miles ago and done another basic reset (flapper control) using vagcom. Scanned the car again after doing over 60 miles and no fault.
When would a fault code/how many miles come back?
Would u say this is fixed?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #18 on: June 30, 2017, 10:34:34 pm »
Probably not, it'll be an intermittent issue. Flaps are only used on idle, overrun and light cruising, and a fault with that system would usually need to happen several times before a code is triggered. Leave it for now and see how it goes
