Author Topic: Jingling/Tinkling noise on spool.  (Read 2067 times)
Offline djhorace
« on: February 04, 2010, 02:26:59 pm »
As per title, does anyone else have this?
There is a thread over on SCN here - http://www.seatcupra.net/forums/showthread.php?t=244058
Offline djhorace
Re: Jingling/Tinkling noise on spool.
« Reply #1 on: February 06, 2010, 11:56:39 am »
Nobody else got this?
Offline micky 32
« Reply #2 on: February 07, 2010, 06:14:53 pm »
I have a KO4 on my vRS and no i don't have that noise.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline Poverty
  • -Given: 36
  • -Receive: 21
Offline djhorace
« Reply #4 on: February 07, 2010, 10:59:25 pm »
Not the same noise by the sound of it mate.
Offline djhorace
« Reply #5 on: February 09, 2010, 03:13:01 pm »
Just spoke to someone who reckons this could be the fuel truss sensor on the inlet manifold. The way he explained it, it goes away when the stock code is on the car which is exactly what happened to mine when I stripped it back last year to sell it.
« Reply #6 on: February 09, 2010, 04:43:27 pm »
I changed mine too, but for a different reason and to something different rather than OEM :innocent:
Offline micky 32
« Reply #7 on: February 09, 2010, 06:56:33 pm »
On the inlet manifold? I thought that was air inlet temp sensor.. Hurdy what have you in place?
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: February 09, 2010, 06:58:39 pm »
yeah as did i, that is the MAP sensor(thrust sensor)
x2 what have you replaced  it with hurdy
Offline micky 32
« Reply #9 on: February 09, 2010, 07:03:35 pm »
I think the map sensor is the one on the plastic pipe going to the throttle body.
« Reply #10 on: February 10, 2010, 12:39:00 am »
OEM part is in front of me now.
06D 130 767C   by KLN stamped on the side.
Still working through logs and set up to see if changing it helps.
It is the pressure limiting valve in the pic below.
http://daz.co/media/hh199/tbuccini/130bar_failure_Hypo.jpg[/img]"]
Offline JettiGLI
« Reply #11 on: July 02, 2010, 09:09:29 pm »
Did anyone solved the partial throttle noise issue? Does the RS4 Fuel return valve solves the problem?
