Author Topic: Fault codes after fitting sports cat, no EML on.  (Read 2214 times)
Offline sean.smithy94
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,107823.0.html
« on: June 26, 2017, 10:01:31 pm »
Hi, on the weekend I fitted my sports cat and downpipe, all is well and good but ive had two fault codes come up but no engine management light on.
P0139
P2196
I will be getting the car remapped but I don't know when due to funds being tight, does anyone know if this is going to be a problem it's it's run like it for a couple of months?
Thanks.
Sent from my SM-G930F using Tapatalk
  • -Receive: 692
Re: Fault codes after fitting sports cat, no EML on.
« Reply #1 on: June 27, 2017, 11:00:28 am »
Both of those are O2 probe faults, not catalyst efficiency faults.   If they are Bank 1 sensor 1, then definitely fix it before driving it.  Probably a knackered sensor, or you damaged the wiring to it when fitting the DP?
If it's sensor 2, ignore it. Get it mapped out.
« Reply #2 on: June 27, 2017, 11:08:42 am »
One of the fault it's saying it's bank 1 sensor 1, which is the front one but I had that replaced two weeks ago so I hope it's not that.
I'm not sure about the wiring as i didn't fit it myself.
