October 06, 2024, 01:25:29 pm
All Things Mk5
How to Guides / Troubleshooting
Fault Codes from fitting sports cat.
Topic: Fault Codes from fitting sports cat. (Read 1434 times)
sean.smithy94
Always Involved
-Given: 11
-Receive: 1
My Ride:
June 27, 2017, 07:38:59 am »
Hi, on the weekend I fitted my sports cat and downpipe, all is well and good but ive had two fault codes come up but no engine management light on.
P0139
P2196
I will be getting the car remapped but I don't know when due to funds being tight, does anyone know if this is going to be a problem it's it's run like it for a couple of months?
Thanks.
Sent from my SM-G930F using Tapatalk
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 685
Re: Fault Codes from fitting sports cat.
Reply #1 on:
June 27, 2017, 11:08:37 am »
Bank 1 sensor 1 (in the DP), check you didn't damage the wiring. Did you unplug it before unbolting it? A lot of people don't and just twist the wiring around on itself, which can bugger it up.
Sensor 2, I wouldn't worry about that one.
All Things Mk5
