Author Topic: VCDS Glasgow  (Read 1199 times)
Offline Spooky211
VCDS Glasgow
« on: June 27, 2017, 08:52:03 am »
Hey guys, I have the dreaded ABS/ESP/Tyre pressure warning lights, only very intermittent at the moment but I'm guessing this will get worse? Was wondering if anyone around Glasgow has VCDS that would be willing to scan my car? Will pay with beer and good chat! :smiley:
MPS
Re: VCDS Glasgow
« Reply #1 on: June 27, 2017, 09:53:30 am »
I've had the same recently. Mine was a Rear Wheel Speed Sensor intermittent fault, it wasn't actually the sensor but the abs ring which is embedded into the wheel hub which was knackered. So you have to replace the entire hub.
Offline Spooky211
Re: VCDS Glasgow
« Reply #2 on: June 27, 2017, 10:23:40 am »
Yeah from other threads it looks to be 1 of those - just need to get it scanned and find out which side! Did you fit it yourself? Was it fairly straight fwd?
MPS
Re: VCDS Glasgow
« Reply #3 on: June 28, 2017, 10:35:58 pm »
No, I used a reputable independent VW specialist. £130. Quality hub like FAG brand (OEM suppliers) is around £80. Don't bother with eBay 30 quid jobs as they tend to last about 5 minutes. Strictly speaking you should change both sides.
« Last Edit: June 29, 2017, 10:37:34 am by MPS »
Offline Sandman
Re: VCDS Glasgow
« Reply #4 on: July 01, 2017, 08:26:05 pm »
I have VCDS and can scan your car for you. I'm in Muirhead.
Offline Spooky211
Re: VCDS Glasgow
« Reply #5 on: July 03, 2017, 12:59:55 pm »
Mate that would be great! When would suit you?
