Author Topic: MDI + 7p6 Loom  (Read 2709 times)
Offline shoaybmakda
  • -Receive: 54
MDI + 7p6 Loom
« on: July 03, 2017, 12:44:51 am »
hi
hope someone can answer this question.
is there a different loom people use for installing an MDI kit and 7p6 bluetooth module? my sound quality on the MDI has dropped since installing the 7p6 module and wasn't sure if a completely different loom is required.
any help is much appreciated
Offline shoaybmakda
  • -Receive: 54
Re: MDI + 7p6 Loom
« Reply #1 on: July 19, 2017, 10:24:03 am »
Bump
Offline shoaybmakda
  • -Receive: 54
Re: MDI + 7p6 Loom
« Reply #2 on: July 27, 2017, 07:44:55 am »
Anyone?
Or can anyone advise if they have MDI and 7p6 Bluetooth fitted and had any issues?
Offline SI-R32
  • -Receive: 125
Re: MDI + 7p6 Loom
« Reply #3 on: July 27, 2017, 09:10:23 am »
What stereo is it going into.
Most vw stereos have different inputs for Bluetooth and MDI, I take it when you've added BT you've piggybacked another loom in via quad lock to quad lock?
Was the MDI already in the car when you got it?
Offline shoaybmakda
  • -Receive: 54
Re: MDI + 7p6 Loom
« Reply #4 on: July 28, 2017, 12:17:28 am »
@SI-R32 its going into an RNS510 if that helps.
i didnt have any of this installed from scratch - i fitted the unit and mdi myself using an MDI loom then had the bluetooth retrofitted with a 7p6 loom so both looms connected in if that makes sense?
Offline Pashka
Re: MDI + 7p6 Loom
« Reply #5 on: July 28, 2017, 06:58:47 am »
Check MDI wires for the speakers if they are not broken. Also, it should be shielded wires for sound signal. And if you use 2 inline looms, i would cut one and solder to each other. Positive, ground, can high, can low. I had similar issue when added aux leads to MDI loom, thin wires got scratched/damaged during the fitting and making the noisy sound.
I have bluetooth, mdi, aux fitted, just no inline looms, everything soldered to the main quad lock.
« Last Edit: July 28, 2017, 07:03:49 am by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline shoaybmakda
  • -Receive: 54
Re: MDI + 7p6 Loom
« Reply #6 on: July 28, 2017, 12:33:35 pm »
@Pashka thanks for that - but that would be way beyond my capabilities I wouldn’t know where to start!
Re: MDI + 7p6 Loom
« Reply #7 on: July 28, 2017, 01:03:39 pm »
i have this kit in mine and it is workin perfect
Jasonrpkj
MDI 7p6 Loom
« Reply #8 on: September 22, 2017, 10:58:22 am »
Seen that thread and was helpful in some ways but not sure if the mdi shelf and loom has the blue tooth loom as well as its a lot of changing around if it hasnt
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: MDI + 7p6 Loom
« Reply #9 on: October 23, 2017, 02:35:48 pm »
Just my two cents after fitting mine on the weekend.
Sound quality wasn't working just right.
I had to get a hammer and hit the connections into place on my unit to get them fully on and it suddenly picked up in quality.
Although I was using the old MFD2 connections so that could have been the problem
