Author Topic: Fault Codes: 012408, 001089 and 000051  (Read 1381 times)
Preece
« on: July 03, 2017, 09:00:58 am »
Hi all,
I have recently purchased a Mk5 Edition 30 and am having a problem with 3 re-occurring fault codes. The DV is the latest revision (albeit not fitted by me) and the car appears to drive well. there is a hesitation on Idle.
Any advice is greatly appreciated  :happy2:
Below are the codes that appeared last night;
3 Faults Found:
012408 - Throttle Control
               P3078 - 002 - Airflow at Idle too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 135706 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:32:25
             Freeze Frame:
                    RPM: 841 /min
                    Load: 19.6 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 142642 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:45:35
             Freeze Frame:
                    RPM: 831 /min
                    Load: 17.2 %
                    Speed: 0.0 km/h
                    Temperature: 81.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 142642 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:45:35
