Author Topic: Bleeding front brakes and topping up fluid?  (Read 1242 times)
Offline trackep
« on: July 04, 2017, 09:59:16 am »
Hi. I plan on fitting my TTRS setup on the weekend. On my past cars i basically fitted the new calipers, then got a friend to pump the peddle and i bled the calipers and kept the fluid topped up. I just thought i would have a quick search on here before the weekend to see if there is anything different with golf and low and behold it looks like it may be a bit more involving than normal.
I'm not bleeding the whole system just the fronts. So will i have to plug the car into VCDS? or can i just do the normal pump the peddle and crack the bleed nipples a few times till the air is gone and keep the reservoir topped up? Last question, can i just use any Dot 4 as a top up? Thanks again Adam
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=e8imh0a8qumude5kak3n29ire4&/topic,19740.0.html
Re: Bleeding front brakes and topping up fluid?
« Reply #1 on: July 04, 2017, 10:37:10 am »
So will i have to plug the car into VCDS? No
 or can i just do the normal pump the peddle and crack the bleed nipples a few times till the air is gone and keep the reservoir topped up?  Yes
Last question, can i just use any Dot 4 as a top up? Use OEM VW stuff
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: July 04, 2017, 11:34:48 am »
I prefer ATE SL.6 DOT4 for normal use (smoother and faster ABS pumping) and Motul RBF600/RBF660 or Castrol SRF for track use. ATE SL.6 is cheap enough.
Offline trackep
« Reply #3 on: July 04, 2017, 01:18:39 pm »
Cheers for the input lads. @rich83 that puts my mind at ease thanks!!!
