Author Topic: How do I wire my rear door entry lights?  (Read 1016 times)
Offline Christiank
  • -Receive: 39
« on: July 04, 2017, 02:39:39 pm »
Hey guys.
So I've got the car splitted and thought I would install entry lights in my rear doors. My car is a MY 2005 so I have to have the cable from the CCM module behond the glovebox. Just not sure which pins I should connect to?
Anyone got acces to ELSAWIN who are kind enough to check which connector and which pins I should use to connect my rear door entry lights?
Offline v4rley
  • -Receive: 104
Re: How do I wire my rear door entry lights?
« Reply #1 on: July 04, 2017, 03:17:18 pm »
You mean the door warning lights where the reflector is?
Offline doylebros
« Reply #2 on: July 04, 2017, 05:23:32 pm »
Offline Christiank
  • -Receive: 39
« Reply #3 on: July 05, 2017, 02:15:10 pm »
Yeah.. Looked through ELSA and couldn't find any diagram showing.. So looked at the Touran and it says you should connect W33(Left rear door ) to F-connector in PIN5 and W34(Right rear door) should connect to PIN12.
Incase anyone should have the same question some other time :)
