Author Topic: ABS & ESP lights stuck on! (Vagcom log)  (Read 1618 times)
Offline Apearcey
« on: July 08, 2017, 04:38:40 pm »
A while ago a friend messed up my ECU by trying to code me a new key on the cheap... Needless to say it messed a fair few things up but anyway we got the ECU working again and now I have an issue where the ABS & ESP lights stay on.
I've already changed the steering controller and the squib thing that goes over the steering spline, neither of those worked.
My brakes work fine, but I can tell I don't have ABS or ESP
Quote
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 01206 210 45725
   VCID: 40889B4213188341A9-8014
4 Faults Found:
00778 - Steering Angle Sensor (G85)
            014 - Defective - Intermittent
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01044 - Control Module Incorrectly Coded
            008 - Implausible Signal
01309 - Power Steering Control Module (J500)
            004 - No Signal/Communication
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.2       1502
   Shop #: WSC 00000 000 00000
   VCID: 316ECE86A8B21AC956-8064
3 Faults Found:
02546 - Steering Limit Stop
             Freeze Frame:
                    Mileage: 640 km
                    Temperature: 38.0°C
                    Voltage: 13.90 V
                    Voltage: 13.70 V
            000 -  -
             Freeze Frame:
End-------------------------(Elapsed Time: 01:41)--------------------------
Offline Apearcey
Re: ABS & ESP lights stuck on! (Vagcom log)
« Reply #1 on: July 10, 2017, 06:39:02 am »
Nobody?
