Author Topic: dB rating of Miltek Resonated vs NonResonated?  (Read 6327 times)
Offline CocoPops
    • Kennet Heath
« on: December 27, 2008, 01:13:12 pm »
Does anyone know the difference in dB ratings?
Full system, just res compared to non res
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Phil Mcavity
Re: dB rating of Miltek Resonated vs NonResonated?
« Reply #1 on: December 27, 2008, 02:18:48 pm »
 :signLOL:, now wheres my db meter gone :smiley:
what difference are you looking for?? what comes out the rear or cabin noise difference?
« Last Edit: December 27, 2008, 02:20:34 pm by Phil Mcavity »
Offline CocoPops
    • Kennet Heath
« Reply #2 on: December 27, 2008, 02:49:31 pm »
What comes out the rear....
ie I have a track day booked, but there's a fairly tight noise limit and I need to know whether to swap centre sections before or after track day.
Offline tony_danza
  • -Receive: 112
« Reply #3 on: December 27, 2008, 03:13:02 pm »
I recently did Donnington with no issues with theirs set at 98db. Non-res milltek and there were plenty louder than mine.
Sideways yo!
Offline CocoPops
    • Kennet Heath
« Reply #4 on: December 27, 2008, 03:16:12 pm »
Bedford operate a 1 strike and you're out, so I need to be sure...
Noise limit: drive by - 101 DB static & Drive By - 87dB at 20m
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #5 on: December 27, 2008, 03:27:26 pm »
What speed is the drive by?
The full non-res Milltek with the SC map on the ED30 is way louder than the normal GTI (like RedRobin's) with the smiliar non-res Milltek, so if the drive by measurement is at any point with the loud peddle pressed hard then 87db might be a bit tight  :confused:
« Reply #6 on: December 27, 2008, 03:42:08 pm »
Lee - That's a tricky question if it's so critical at Donnington - I would phone Charlie or Dave Marshall at Milltek 01332 227 280, they are both very helpful and will know as it's a common question.
Offline jonnyc
  • Herrooooo!
« Reply #7 on: December 27, 2008, 04:24:22 pm »
Milltek is very quiet either way..
I had full 3" on the S3 with one tiny box at the rear and the big turbo, which made it a hell of a lot louder and mine was 103 static, the Veil tuning car with a Milltek exhaust and same turbo etc was 89db.. Dont worry : )
« Reply #8 on: December 27, 2008, 04:36:06 pm »
as jonny says dont worry they are more than ok and its a 4pot so they are not loud anyway  :wink:
Offline GTIjames
« Reply #9 on: December 27, 2008, 06:08:09 pm »
track day i went on had a rather low dB rating around 95 i think, that was goodwood, have full tbe resonated. they test is parked with a prong up the exhaust and you rev in neutral, good thing is dsg only lets you rev up to a point and got no where near to the sound limit with rev limiter, not sure with manual though,
Offline jonnyc
  • Herrooooo!
« Reply #10 on: December 27, 2008, 06:58:19 pm »
Should only be 3/4 revs with a static noise test anyways which you could say was 4875 based on the 6500 red line on the clocks..
DSG only allows 4k I think, either way Milltek is not loud  :happy2: (3" straight pipe is)
